The output to the LED is parallel. led+ and led+ together, to the led. led- and led- together to the led. This gives you twice the voltage. It's a parallel circuit to the led. It's just like two batteries in parallel. + to + and - to - gives you parallel, that increases the voltage. Series is + to - and increases the amperage. Actually this set-up increases both, as it really is series parallel. The removal of the slave controller and the wire from master VDD to slave VDD on the 7135 circuit produces control to all 7135 chips.
Am I missing something here? I don't think so, but I could be wrong, (like just about every day).
EDIT: Yes, I am wrong. Completely wrong and worst of all I still don't get it.
Nope, that's backwards. Parallel doubles the amperage, series doubles the voltage, and down to the way 7135s regulate only on the negative path you can't connect them in series. Too bad they don't work like DC power supplies, huh?
You'll have to have either the supply voltage above the LED's Vf (2s2p lithiums at 8.4v) (and then, either use a buck driver, or use a work-around to keep the 105C's MCU alive at the higher voltage and try to get the 7135s to burn off the excess ~2.5v), OR, use a boost driver if you stick with 4s NiMH.
Well, that is ass backwards. Makes me feel like the fool that I am. I feel like slinking away after this bit of stupidity. My apologies for not knowing my arse from a …
It’s pretty well documented by me and one or two others that 6V is not a problem for the 7135 chips if the led is dropping most of the voltage. Then all you need is a voltage regulator IC to maintain 3-5V to the Attiny mcu. That done, master/slave works fine. I personally have run up to 12V with 3 series XML this way. For 6V input I would use an LD2981 5V chip like this.
In this thread, Rufusbduck does some pretty extensive experimentation with a Nanjg 105c type driver. In post 43, 4th picture down, there is an actual example of what he is talking about above. Please correct me if I’m wrong Rufusbduck.
Well, after a bad session with this light, I have decided to put it on hold. This may be a real Sky Ray, but after what I have seen tonight, it probably is a poor clone. The head to body is a mismatch. If a single reflector is put in the head, it is not centered. It is off center which means when you turn the head, the led hole would look like it is turning in an oval. If you have ever seen an off center reflector, you will understand what I am trying to say. Maybe not the best explanation, but anyhow either the head or body was not cut true. You could never take the head off, without taking the reflector out first. If it were turned off, it would wipe out the led dome. With the stock 3-up, it wouldn't matter, since the reflector and LEDs are stationary to each other, but with a single reflector it shows up big time.
Also the threads are super sloppy and you can almost pull the head right off the body because the threads are so bad. It's fairly depressing to see the lack of quality there and compared to the Fandyfire I had, it's just poorly machined, plain and simple.
I put it up till I figure out if I bother with it or maybe get another fandyfire to use as a host. It's a real shame.
Yep, I see the same things on the one I just got. The OD of the battery tube o-ring is 1.980", the ID of the o-ring bore in the head is 1.988", it doesn't even touch. Also they've switched to a much thinner lens and make up for it with a super fat o-ring to use as a spacer. The crown bezel is aluminum, instead of stainless.
This isn't about fake-vs.-genuine, as all of them are copies. But I think they've finally crossed that line where the lower price no longer makes the flaws tolerable. Flaws that don't affect the function are one thing, but o-rings that don't actually seal are kinda a deal breaker. Why didn't they just omit the o-rings? They could have saved another .00031 cents per unit.
Anyone know of a source for a better quality BLACK SRK?
Bummer. Sorry to hear about that. Sounds like it would be best to keep the original driver now so that you can easily reconstitute the light in to its original form. Would it be improper for any of us that feel compelled to “opt out” of the giveaway so that you could do that? I hope I don’t offend you by asking this. I am totally asking with the highest respect. You unselfishly give so much to this forum.
Its a shame about the quality.
Old-Lumens and Comfychair, where did you get black SRK come from?
If its from FT, please give them a notice, they seem to care about such matters and will hopefully find a better source.
If color is not an issue. Gold SRK can currently be bought for 32$ from Wallbuys (sale + discount code). I have yet to hear people complain about such matters on them. But you never know…
Thread about the sale here.
CNQG was the original seller of the black SRK and I believe those were very good quality.
I'm not going to bother with Fasttech, since I'm never going to ship it back (costly) and since I have torn it down for modding, they can't really do much. I accepted it initially and tore it down. I should have inspected it better first.
I imagine I will pick it up again sometime and finish it, but I would probably have to center the led with the reflector, mark reflector and head for position and Nitecore the head on the body, so no one can twist it off That way it will look centered, even though it's not. That would mean loading batteries from the tail.
That’s a bluesy song written by Winkler & Hathcock made famous by Jim Reeves in ’62 but I grew up on the Dean Martin version (only singer I know who sings from a sofa) :
