Funny design ;).
Have you thought about screw terminals for the led leads? Soldering such big wires isn’t always the best way.
The design specification was at least 3x3mm solder pads for the LED wires
That design has no space for screw stuff as it is limited to 5mm total thickness
5 hours of designing this board
It’s certainly very nice that you are actually doing this!
The shape reminded me of this movie…
Thanks I am still making small improvements to the cooling system, when it is finalized I will post more pictures of it and explain everything.
Currently the tubing I’m using is too thick and stiff, and is pushing on the reflector too much.
Also there’s a tubing run in the way of removing the reflector so I’m gonna need to split the single copper coil into two pieces so that one is water to the LED and one is water back from LED, instead of how it is now, which is coil to the LED and then extra tubing run going back to the pump.
Yeah, it is really unique, very few LED lights that have a recoil reflector, usually it is just short arcs.
I wanted to try new things Also wanted more lux than the optofire without spending $1000 on a custom lens.
Yeah, I think I will need to do that.
What do you guys think of RecoilBeam?
I will no longer put the name of the LED in the name too many possibilities of LED swaps.
Thanks so much for helping me out in making this possible
I won’t need to have a big ugly external driver strapped to the light to use a CFT90!
Lol nice photoshop, you even got the size perfect!
About your water pump, do you have room for a larger one that would have to work less hard?
Nope, there is close to 0 space left!
It’s not getting hot now that it’s heatsinked well though.
RecoilBeam reminds me on those small ultrafire recoil led flashlights (UF 007, 008), and it will mess google search by bringing them into search results.
Be more creative than that .
Enderbeam
Or maybe Enderman Endlessbeam
Wow.. pretty sick stuff here! That is impressive!
EnderFire™.
LuminousBeam™
Model CFT-90
Sick!
Awesome You gotta find a way to “shrink it” and make it the pocket thrower of the century :smiling_imp:
Nice work :+1:
Don’t forget to machine an attack-bezel for it!
After all, it wouldn’t be “tactical” without one! :smiling_imp:
NeverEnderBeam :person_facepalming:
