Had time today and successfully dedomed my Thorfire TG06. I used the solvent method and it was my first dedome. It is quite a difference, the tint is much more neutral now and the light modes are all the same spacing as before, but it seems a bit more bright with the new tint. The beam is much more compact… I did not take any pictures before and will try to get some up here in a day or two. I killed one of my Hugsby XP-1’s trying to dedome it after this success, but I will put a new emitter on when they arrive from the place I ordered them. Now I want to dedome the Hugsby P31… this is fun…
I put in a different driver and emitter on my TG06 DRIVEREMITTER Both items are from BangGood and are non-affiliated links.
No real issues with the mod, the bigger LED fit the reflector fine. The driver required filing to fit into the pill, so if you do this mod have some patience and a fine file…. Alkaline or NiMh only now…
A GIF of the DeDomed standard TG06 I changed the GIF to L-M-H order from the original L-H-M UI.
And the Modded TG06 from the same distance and the same camera settings. Three modes, L-M-H and a LOT more light.
I did not have any pics of the original LED prior to DeDoming it… But the DeDome made it more yellow and increased the spot, but about the same amount of light… so this is pretty close except for the color to original on Alkaline.
I had some issues filing the driver down to fit, mainly frustration as I did not want to go too far and damage something. Taking it slow helps. The XM-L is a 6k and not as blue as the original. NO PWM on this driver, I lost the 14500 ability, but who cares, this rocks on an Alkaline now and work supplies me with them as I use the light on my hardhat….
Got it in today from EverBuying - $12.53 (at that time) minus $2 of points, so paid $10.53. Mode arrangement of lo-hi-med is a little weird but works. Good quality light - brass pill, PCB mounted tail switch, exc. threads, exc. finish.
Nice write up with some real numbers! If you do not like the color, just switch out the emitter, cheap enough alternative. I should have tried that before all the driver swap filing. Thanks again for the numbers on this…
I'll probably go with an XP-L on copper and a full blown DD FET driver - 17mm filed down. I like pocket rockets. I have a UniqueFire G10 that does about 1,100 lumens on a EFEST 14500 (XP-L and DD driver). Expect I can get the same on this, but the TG06 is smaller overall.
Don't hold your breath - dunno when I can get to it . Was surprised to see you went with an old style XML T6 on an aluminum star. Definite boost over stock, but an XM-L2 (U2, U3, U4, etc.) on a 16mm Noctigon would have been a better deal - roughly same cost, much more output, better heat sinking, etc.
Close to finishing of the mod of this light. The original driver is about 16 mm. I dremeled/sanded down a wight FET+1 driver to fit, and it works fine. Got custom NOINIT firmware that has first 3 modes on the 7135, then 2 more on the FET, just like I have in my e-switch firmware. I soldered the FET+1 driver at 3 places to the brass pill on the top, and seems to hold well. I aligned the back tab of the 7135 to one of the two slots cut out of the brass pill in order to get the driver to seat down properly. Sanding it down puts the 7135 tab very close to the edge, so it interfered with the pill ledge. Now it fits very well - nearly flush to the pill's edge. I took pics, will post hopefully this eve.
It's got a XP-L V6 3D on a Noctigon - looks real nice with the small OP beam pattern. I put in a 45 sec turbo timeout - should get hot. Not tested on fresh EFEST's yet, and still need to bypass the tailcap spring, etc. Should do at least 1,100 lumens.
Ahhh, forgot a SK68. The one to the right of the TG06 is the slim AA zoomie - that one is from GearBest. Yes - the button is the big size, 16 mm I believe. Actually I replaced it because the stock one kind of bulged up a little. The replacement fit well and seems to have a lower profile, so I think it's tailstanding better.
It's a nice quality host for sure - I'd say same quality as a Convoy or Eagle Eye X6. It's got the small white Omten switch - decent. I went for lumens more than throw, with the XP-L, but has a nice soft hot spot with the OP reflector. The smooth knurling is like an X6. Also has the quality smooth 2 hole support for a lanyard. The 5 modes I set it up with is a bit too much maybe, but with this power, it works well. It's a NOINIT based driver, using the brown out detection for OFF time memory.
The reflector is smaller in width than the G10's, and much smaller than the SC01, in the pic to the left, but bigger than the small form factor AA lights.
If/when I get one, it will probably get a Nichia 219C (I have two sitting here that I can’t decide on a place for) and a moonlight driver with 2amp max. I think it would become my EDC.
That is a great mod. Where did you get your parts by the way? I like the copper disks and had not seen those anywhere. Did you have to build the driver yourself, or was it pre made? Let us know your sources if you get the chance.
Yes, all above true. Got the copper rounds from the "bopper" on Etsy, originally recommended by O-L. I have a supply on hand of various diameter copper rounds, I believe 18 gauge is the max thickness they make. You can message Beverly, shop here: https://www.etsy.com/shop/Bopper, and ask for any custom sizes or quantity. She has the best prices I could find, but these copper rounds aren't made for what we use them for, so they aren't perfectly flat. I usually sand them down to at or near flat before installing them (basically they bulge up - one side bumps out in the middle, the other side has a center indent. Since the pill is brass, could reflow the disc to the pill. For alum pills, I use Arctic thermal epoxy.
I had the emitter bare, reflowed to a 16mm Noctigon. The Noctigon needed no trimming/sanding - fit perfect.
The driver is this: https://budgetlightforum.com/t/-/31102. Sanding down to 16mm gets a little hairy. The grnd tab of the 7135 was interfering with it sitting on the lip in the brass pill, but the pill has those 2 cutouts in it. So, if you align the 7135 tab to one of the cutouts, it seats down perfectly.
