TK's Emisar D4 review
Skittle. If for some reason you do it again you’ll notice the light blinks when you insert it correctly and screw the cap down
Skittle, does the light still work afterward, when given a working battery? In other words, was the damage limited to just the battery?
To improve reversed-battery behavior, the driver hardware would need to be redesigned. The firmware (LVP) can’t do anything about it since it can’t run unless it has the correct voltage. I’m not sure what measures can be taken, but I would hope that it would simply do nothing instead of draining the cell. That’s up to the analog circuit designer though; it’s not something I can fix.
A worried friend had already got his d4 and d1s yesterday, and since they didn’t officially start selling, d4 hasn’t been tagged yet. The structure and length of cyan d4 have not changed, except that the surface of the frosted surface, its body and old d4 can be exchanged for use, this is the photo he Shared.
I guess I’m finally deciding myself to go for this light :person_facepalming:
I’ve been reading and watching the photos and now I need to decide the emitter to pick.
Can anyone compare or show this one in particular? XP-G2 S4 3D, 4885K
I’ve seen the comparisons between XP-G2 S4 5D, 4000K and Nichia 219CT 90CRI, 5000K, but unless I missed it, I guess I didn’t see any of the 4885K.
I’d appreciate to see one if anyone has it :+1: Thanks in advance! :wink:
Yes, the light is fine. So RPP works as intended—it just has an unintentional flaw that eats batteries. It shouldn’t be a problem unless you’re used to putting batteries in backwards (ahem, Olight).
Is your friend called Hank :wink:
Nice pics, thanks for sharing………………i can see this Emisar! family forever growing in size :smiley:
As an intense Olight user (S baton Series), I totally understand why you would put a battery bacwards…
Emisar’s feature of blinking twice when fed a new battery is really useful for that matter
That blue one looks nice… and the D1 looks very portable and convenient. The D1S looks a bit large for my purse though.
You have a good reason to buy a new bigger purse. :smiley:
Is the xp-l hi worth the price difference in real life performance? Also is the side button easy to locate in the dark? Thanks.
I’m dealing with that issue right now. I like my XP-G 4000k better than my XP-L 5000k. I try to love the XP-L more, but can’t.
Dark Raspberry sounds good for December.
Grainy Tangerine… :blush:
Are GITD pigments destroyed during anodization?
uuuummmmmmmmmmmmm…… ;.)
I’d definitely be in for a Tangerine D4 :smiley:
Well I just ordered the cyan and new green grainy D4 lights. Both 219C. Finally 90+ CRI… Just awesome. :partying_face:
+1
