LOL, that’s ridiculous, muggle mode is (imho) one of the most actually practical features of the Anduril UI and would be the only reason I would take it over Ramping IOSV2 in a D4. There is no sense removing it since it’s quit deeply hidden and accidental activation is impossible.
I agree, especially on these small lights. Right now I just use the stepped ramp for lower output, but its easy to figure out how to switch.
Personally I wish momentary was better hidden since it needs power disconnected to be disabled. Something impossible to do accidentally like 8 clicks vs sandwiching it between lockout and muggle.
So… I was a bit of an idiot and forgot to remove the cell when swapping the mcpcb. I managed to short the LED+ to the body for a fraction of second. Everything worked fine, but the regulated modes were much lower; moonlight was the brightness when doing a diode test with a multimeter. The 100% 7135 mode was about half as bright as it should be. FET modes are completely fine, as are all the blinkies & such.
Anyway, I’ve replaced the 7135 and I’ve still got the exact same problem. I was thinking it could be the attiny chip, but all the software features work. Any ideas?
wondering if one of the resistors got fried, and the 7135 is not getting fully enabled? If you can measure the resistance and its higher than marked on the part, that would suggest something. Of course if the resistance is lower, than its hard to say if there’s a parallel path somewhere causing that.
Yes, the version with RampingIOS V2 is the “original D4”. RampingIOS V1 was only shipped on a small handful of lights, so it was basically an unplanned beta test.
That’s odd. The D4 bezel normally comes off really easily, just by grabbing it and twisting.
I would say get a new driver board. I messed up programming one of mine, and was able to purchase a replacement from Mtn Electroncics for like $5 shipped.
My new D4 with SST20s, 4000K, arrived today, ordered on May 16.
I asked Hank to flash it with Anduril... check! The version on mine does not have muggle mode.
I've been using a Sofirn SP32A clip, additionally secured with a hose washer, on my other D4 and even clipped to a cap, it holds strong and won't fall easily. Just to keep it in the family, I ordered Hanks latest clip offering and I haven't noticed anything negative about it. Good clip.
And as a BONUS!, I received an LG HG2 inside the light. I think he must have been testing this custom build with it but Thank You! nonetheless.
With the UI of this light, I could almost forget my other lights! For trips, it's certainly my default side-light cannon. I only 'need' a thrower and standard tube light (S2+, SP32A, etc.) to round out the potential niches.
Someone created a listing on eBay for a new “Gen 2” Emisar D4. Oddly enough, it asks buyers not to purchase it, and it says that it will be available in a week.
black/gray/sand
aux leds
polished stainless steel head (optional)
magnetic tail cap (optional)
There are some photos, and the flashlight looks great. It doesn’t look like this was posted anywhere else yet, so it is possibly (likely?) fake.
EDIT:
Photos look very similar to others Hank uses for D4/D4S. It might not be fake, more likely someone decided to leak it before Hank officially announced it.
I have seen several overpriced D4s on ebay, although I have not paid close attention to the colors. Gen2 = Anduril maybe? Or more likely he’s adding Lexel’ aux light board, a magnetic tailcap, and quadrupling the price.
It does not look like fake, the changes that you see make too much sense: nice knurling on the 18650 tube and the 18500 tube, finally a cool SS bezel, aux leds, and most important: a promising-looking recessed switch.
