Wanted to add your light to my mtg2 throw thread if the number was known. I suspect this build has the highest mtg2 throw of lights in the reflector flashlight format. Thank you for the fast reply Flash.
Youre welcome. I thought that might be your intent. Ive been swamped but have been meaning to contact you. Not only does the X7 take very good advantage of the MT-G2, but its one of the easiest mods Ive ever done, and super inexpensive compared to lesser performing name brand lights.
How does the reflector compare to the X6? It seems the X7 and X6 have the same external bezel diameter. Is the only difference the driver and emitter, or is the reflector deeper for the X6?
Sorry, but my MT-G2 conversion required a compression fit between the star, copper disk (that I added) and pill. It took forever to get it all perfectly centered, so Im not going to take it apart again.
If you search BLF for X7 Aspheric you’ll find it has been done before.
Thanks FlashPilot, i did not expect to be that narrow, knowing that the head diameter is 80mm.
Anyway, I already ordered the lens, If i need to machine a custom bezel, so be it.
light junkie, I ordered the X7 directly from Trustfire store on alibaba.com, it was 50$ link
A very small price for a awesome light.
Thats a real steal for this light. Youre going to be very impressed with it. This thread indicates the reflector is 71mm. Have you checked out what 18sixfifty did to his X7 before he sold it? His monster aspheric mod threw more like a laser than a flashlight.
I tried to get Focalprice to match the ali price here in post 17 but of course focal is a worthless store and not good for much of anything.
If you get tired of playing with XM-L, drop an MT-G2 in it and have more lux than any production MT-G2 light available… super easy mod with only a 20mm copper disk behind the mcpcb. No other mods necessary!
This is an awesome light. I have the 5000K 80+ CRI MT-G2 in one light, I just ordered the 3000K 90+ CRI MT-G2 for another, and I’m not sure what I want to do with the third—maybe another MT-G2.
If anyone has any questions on measurements or wants specific pictures, ask away!
Im glad that you discovered how well this light caters to the MT-G2. Can you please post your tail amp measurement in high mode with 3 fully charged cells (if you are able)? Thanks.
FlashPilot, my apologies for not doing this earlier! I’m in exam mode right now, so all my flashlight stuff is packed away twitch
But I’ll tell you what, I’ll mark it in my calendar to run the test when my exams are over.
In the mean time, I can tell you that I ran similar tests to yours when I performed the upgrade. If I recall correctly, my tail cap currents were in line with yours. I can confirm in about two weeks.
Thanks Rollinstone. Since there are many variations of this driver in other lights or sold separately, Im curious if my stock driver performed within the normal range as shipped with this particular light. I certainly didnt expect such a high tailcap current with MT-G2… not that Im complaining. :bigsmile:
If you haven’t tried the 3000K 90 CRI MT-G2 yet, you really should—it’s awesome! The color is slightly whiter than a classic incandescent, the color rendition is noticeably better than the 5000K MT-G2. Seeing how well the 5000K 80 CRI MT-G2 renders color, that statement carries a lot of weight. It’s also easier on the eyes than the piercing white of the 5000K MT-G2. I certainly appreciate both quite a lot, but I have a soft spot in my heart for the lesser known of the MT-G2’s!
I think I’m going to gift my dad the one with the 3000K MT-G2 along with some NCR18650B’s and a NiteCore i4. Still need to pot the driver, upgrade the wiring, and adjust my copper emitter spacers (I used 2 discs, 1 would be better!) but I think he will like that light quite a lot.
Have you had any issues with protected cells? I have an obscene collection of laptop pulls right now so I’ve been using those with this light.
Its interesting that you mentioned the 3K/90 MTG2. Ive been considering that one for a while, but I prefer a cooler white/higher K for higher contrast in most of my flashlights. 1A XML has been my preference in most builds. Ive compared the tint of my X7 - 5K/80 MTG2 directly to my XML 3C flashlights, and they seem about identical. I completely agree with your assessment that high CRI is definitely more friendly with the eyes. Especially when used in wide area flood lighting/casual/lazy/drink a beer/pinch your girls butt, type of settings. :bigsmile:
Ive been running a large rare 3K/97 CRI Bridgelux RS emitter at full rated output @100 watts/3.75A for 7140 lumens. How do I set up a Meanwell CV/CC driver for my Bridgelux array? Beyond the sheer even blanket of light, the mega-CRI is what makes me smile the most. Girlfriend seems to like it too… time for a pinch. Haha!
Its a great time to be alive for the LED lumen junkie. There’s so many great choices, and one for everyone.
I doubt you’ll see a bump by running larger wires or potting unless you resistor mod for higher amps. If your driver delivers the amps mine does, eeking more out of it will give you a light that overheats very quickly and with diminishing gains in lumens. IMO, mine delivers about 1 amp more to the emitter than Id consider optimum for 3 x 18650/heat/runtime in this host combo. My take: leave it as is and smile that you have a great one to play with. Speaking of which, can you please get a tail current in high mode when you have a chance? I guess I should also ask of you have a decent DMM… just a reminder.
I personal dont use protected cells to often. But then, I always test cell voltage a day after charging and match my cells by voltage before they go into a serial config light. I also test voltage again after the run. Maybe thats overkill for some, but for many its not. I dont think the X7 driver has a low voltage warning, so its probably not the best gift for someone that isnt going to be religious about testing voltage as just mentioned. I tend to sell very few serial lights because most people could get into trouble with them (even while using protected cells).
I just checked 2 versions of NCR18650B’s for you. Protected cells will fit but only allow you to screw down the tail cap 1/2 of the way. Unprotected button tops are a perfect fit.
