Hey tterev3 (and anyone else)- got another crazy issue, not saying it’s perminate (hoping the opposite) but I seemed to have bricked my clone PK3 2 days ago and I can not recover, even tried an old computer (that always worked)…
So the story is, I was doing some code work with the programmer hooked up and wired to a driver, I was flashing and testing and flashing and testing. My computer was giving me a “needs to restart” prompt that I kept postponing, I didn’t realize the button I pressed that last time to clear it was just that- an “ok” button, not a postpone. After 5 minutes my computer forced a restart (and installed some pending updated), I also lost all my code work but oh well. Once it finally came back up I wasn’t able to connect to the chip, I continously get the “incorrect device signature” warning.
I was working in MPLAX 8.92, I have since tried downloading X 2.2, neither can communicate with the chip, on X there is an override for that error so I tried that and it can’t communicate still.
I have downloaded the newest PK3 FW however in my device manager PK3 is only showing up as a random USB device and the listed drivers are simply “Microsoft” (but they do show UTD).
I guess my question is- what does your PK3’s show up as in device manager?
Note I’ve tried no fewer than 10, brand new- straight out of the tape 12F617’s. I was somewhat concerned about that because I got that strip of 50 617’s from aliexpress (but I’ve already used around a dozen of those without issue) so I then tried some 10F322’s new out of the strip that came from digikey, still the same thing.
I have also hooked to the chip several different ways, using an SOIC clip, solderong the chip on a board and soldering leads to programming pads on it, even solderong directly to the chip hanging in the air.
I have also tried with and without a .1uf cap from VSS-VDD (can you tell I’ve been googling).
Note2- I physically took my PK3 apart to verify it didn’t suffer from the clone FDTI Chip issue since it happened right after a windows update, it doesn’t, it uses some microchip part for USB data handling. All parts on the board appear to be legit, 2 main microchip chip’s and an Atmel (plus an AO FET and several more). The only thing that gives away its a clone is the lack of a microchip logo on the case.
