I will try today if possible to add an copper cord on the edge of the retaining ring on the tail cap, let’s see if it is a good solution for those wondering to use long batteries such as Hi-Max, protected NCR1650A…
All you need to do is remove the ring and add something 3 or 4 mm thick and long batteries will work. A 2032 battery will work but wrap it in tape. A 20mm magnet would be ideal.
Ok. So I’m thinking about buying EagleTac 2500 mAh, these are 68,2 mm x 18,3 mm. These are not too long aren’t they? Thickness should be good if the tube is 18,7 mm.
I didn’t measure mine, but my Hi max did fit with no problem, I believe there are more probabilities some hi max are thicker than others than different tubes on the flaslights.
remove the ring/ spring etc and put something in the bottom of the tailcap and then replace the spring and retaining ring. The magnet from the ufh3 fits and works well.
I’ll see what can I do edc, I tried yesterday with a thicker magnet, using it, the light can be placed on any direction with no problem the only con is with the existing ring etc, there are not enought threads left on the tail cap to screw it.
the PWM isnt that bad at all. overall. It is a nice light for the price. Comparing to H600 Zebralight. I believe Zebralight is of cos better. The switch is really recessed. It is a small electronic switch.
i have this looks amazing but u i is not good you have to hold for around two sec when you turn it off or it will start up again in low, its a pretty good edc, i would say hi only 500 otf lumens good beam not as floody as zeb sc 600 so has some throw however the button is too small to use it as a headlight at work if you wear gloves,i have most high end headlights but still in general feel the ultrafire p10 r5 with a good headband is the best
Agreed, plus holding the button for 2 seconds to activate memory. Other than that, it's a great headlamp. The PWM isn't noticeable to my eyes, unless I shine it at a fan. To me that's insignificant. I got mine from Manifont for $39 shipped
BTW, I use mine strictly for close up work on electronics, etc. It works incredibly well!
