I think u have to be realistic its a big light i doubt it will sell for around 150$, close to 200 then more like but who knows… it would still be under blf gt price.
I have over 150 lights, I find that there are those that I like best and as such I use those most often. Periodically I mix it up with some rotation but there are a lot of my lights that don’t get used. Nevertheless every single light in my line-up has a charged cell/cells installed and is in stand-by mode for instant use at any time.
Off topic, but how often do you check your batteries in your 150 flashlights for parasitic drain?
I don’t have parasitic drain. If the light is an e-switch light I manually break contact with a loosening of the tailcap or tube.
I’m extremely forgetful and have little “time sense” so it might be a couple of months before I check cells or it might be a year, it varies. Sometimes I get to looking for a specific cell and go through most of the lights, usually when I do that I charge em 30 or so at a time so they all go back on the shelves topped off.
I think I should start manually breaking the contacts too on some of mine. I like the lighted switches on my shelf and the drain is so low that when I do check battery voltage, it doesn't move much, but there is that tiny risk factor that all of a sudden a fault shows up and they do drain fast.
Just received my Mateminco MT35 Plus in the mail 2 days ago, took 6 wks from order time. Have not had a chance to play with it yet, with working and helping Wife babysitting Grandchildren all week.
Not sure why Alibaba is making these, guess they will be in a contract with Astrolux to build the MF04. You guys are experienced with China and hoping you can shead some light on the process.
Here is a link for more info and pics by a “Mr. Mak” ( I’m guessing ). You will need to translate the language.
Note: You can run 2 flashlight heads together at the same time, see the pics in the link.
I believe Alibaba is just a storefront made up of many different suppliers. Something like that. They don’t actually make anything.
Mateminco is the company making the lights and they sell them in China as the Mateminco brand or sell them internationaly as Astrolux through Banggood. Astrolux is Banggoods house brand.
Nice. I am glad you like it. i think astrolux nailed it…
Pros…
Will shine 1.89 km or 1.17 mles. ( from steel beamshot )
Led is perfectly centered and sit correctly…
boost driver.
Very efficient…
4 modes… nice and simple!
New upgrade design battery carrier
Improved and solid indicator switch.
CW or NW option available.
