Sorry I'm only 17 and I'm a beginner at electronics, if even. If you could tell how to measure the Amps I may be able to do it. I ones of those Digi multimeter things that might be the tool to do it.
I got 3.18 Amps on these with a rev jim unprotected panasonic ..More than my 980L and keygo ke5 .. not much more ...but more . the med is pretty low and i like the 3 mode ...(sorta)..only one obnoxious flashy to pass by.E1320 says the driver is a cheap one that Kaidomain uses too(unverified) tint and beam quality isn't perfect butnot bad .. I've seen worse for much more money .at this price it's a gift..You can add a battery and charger and still be under 20$ .. pretty amazing to me.
I think you did it right. The results can vary with the battery as well as the driver; I don't know if that would account for the difference between your result and that of Boaz or not.
I was using a red Ultrafire 3000mAh PROTECTED battery.
On my second attempt my test results are around the same still, 1.7 amps. I set the multimeter to the settings that shows "A" then 3 dots under a line and the 20m.
Ok a couple shots of the driver (as far as I'm willing to take it apart because there is always a 50/50 chance of me breaking something when I take things too far apart).
If you need a different angle or the Driver to be pulled apart more, your going to have to give me instructions because i'm not sure how.
EDIT: You can right click on the picture and choose view picture to see the original size image.
Seems like there is some small particles in that XM-L emitter dome. Not scared of them for this price though, DX has had them in every XM-L cheap´o headlamp I´ve ordered to my friends.
