That Maserin looks really classy. :+1:
Weekend combo: Field Cleaver and my new FURA titanium flipper (review here).
CRKT Foresight
I once had a knife looking like that, maybe a bit less hight blade and then it off course dident have that hole, and then worst of all it had no lock what so ever.
Cant remember brand as this is around 35 years ago, and it was one i âfoundâ in a place we broke into as kids, dont worry i am not like that anymore.
I have aa feeling it was some sort of fruit /vegetable knife or something, the blade was 110 mm or so long and it was quite thick too so the knife had a okay chop to it, just had to make damn sure you hit something with the no lock blade.
Spyderco Endura 4 VG-10 FFG Zome Green
I have been EDC-ing this (Serge Panchenko clone) small Fura knife for two months now. I work in a school so I can not pull a scary knife out of my pocket, and this little knife does all the usual stuff that I do: opening boxes and packages, peeling apples etc.
Kizer Sliver (aka sunburst)
(yellow one lately)
Hey, about thatâŚ
Regular cheapie knives, I try to keep them clean (ie, slicing open envelopes and boxes, sure, but peeling juicy fruits and stuff, not so much), but if I were to go peeling kiwis and oranges, what kind of cleaning is okay?
Ie, I wouldnât want to go crazy cleaning out every nook and cranny with detergent, not if itâs going to strip out lubricants and the like, and relubing involves⌠what?
Ăons ago, I carried a small Buck clone, and while Iâd scrub out the pocket-lint thatâd collect, I never had to really clean it, as I never used it for fruits and stuff. And it never seemed to need any lube.
Now, with my new Ganzos and Sanremus and such, Iâm not sure about the steels involved, whether theyâd pit if using bleach on them (as regular SS does), or removing lube and having to relube (oil? silicone/lithium grease? etc.), probably some food-safe lube if I want to go back to cutting fruit.
So what do yâall usually do?
As I use mostly stainless steel knives (VG-10, AUS-8 or in case above S35VN) I donât feel so bad if I clean them manually under water regularly. If you use knife for slicing food, you need to do this anyway.
Then I use Ballistol H1 spray lube. Itâs food safe and it doesnât have some annoying smell.
Hmm, tnx! I figured that slicing into a mango or tauntaun (like last week during our cold-snap) could get messy with a folder, but Iâm not about to holster a fixed blade at work, as thatâs generally Frowned Upon.
I just wanted to make sure that repeated washings wouldnât cause rust, and not wash out all the lube.
That H1 sounds good.
I regularly use a 440C Ganzo, a 12c27 Opinel and a VG-10. All I do is rinse them with hot water and dry them with a towel after each use. I canât imagine why youâd need to use bleach.
I try to keep water away from the pivot but if lubrication is required I use food grade mineral oil. I got the oil from my local pharmacy (itâs sold as a laxative) and I also use it on wooden cutting boards.
The best way to keep your pocket knife clean is with compressed air if you have it at hand, like on job or in a car shop, etc.
Blow out dust and lit or wash it with water and dishwasher, blow out the water, ready to go.
Lube make a good ss knife (sometimes) better, but itâs not always necessary.
My Sanrenmu 910+ with ball bearing runs better dry than with lube, the original grease even slowed the action.
On my Kershaw Chill, one of the smoothest flippers with washers, I donât need any lube after I polished the washers, on ball bearing I just didnât find the need to lube them as of yet.
The only place where I like to add a drip of oil is the detent track as the steel ball likes to catch dirt which is difficult to blow away.
Better to put a piece of (magazine) paper between the ball and the blade surface by slightly overbending the frame lock and then opening(closing the knife with the paper in between.
If you have an all steel folder like the SRM 9103/4 you can also clean them under hot water, this way it dries faster.
On liner lock knives I donât like it that cleaning it with water will leave some of it under the scales but itâs easy to disassemble them later and clean them.
Good advice, all, tnx!
Froglube is a good lubricant and rust preventer that is food safe. But like any âwetâ lube, it will attract dust and lint easily.
ZT ⌠0566 âŚ
Sporting the Ganzo today âŚ
Kershaw Malt 5520
