Did my first led reflow today. A 5D1 80+CRI in my S1 mini ti, great tint.
Just put the star in the center of my gas stove, not nearly as difficult as I thought this would be.
Nice. I think the question there isnât about the reflow, but about how you got the bezel off without scratching anything.
Youâre welcome
Hammer + knife, whatâs not to love ?
Very COOL and well done vid Geuzzzzzzzzzz! :+1:
Thank you, that video is mine :innocent:
Oh in that case, itâs still good X3!!! :+1:
Then thanks for posting X3âs very cool and well done vid Geuzzzz!!!
XHP70 P2-1C Surefire Millennium Series M3 COMBATLIGHT
I bored it out for 18500 Efest batteries, and still retains the captive shoulder, so swapping out heads is possible, with out loosing batteries. I have XHP50 and MT-G2âs also. It is running a 2S FETDDSir800 Guppy Drv.Rev 1, Custom Reflector ( made by Dan in Hong Kong) and Copper pill (designed by me, made by Sinner) the head and body is fully thermally potted, reflector is on the glass, omitting the shock absorbing foam for more OTF Lumens, plus an original Zero Rez Oveready custom Z44 switch.
The XHP70 P2-1C is pulling 10.33 amps in Turbo! :sunglasses: One bright Surefire now!! :+1:
Very cool KawiBoy!! 8) 8)
Thanks jozz! LiterallyâŠâŠ Cool (white) more like Ice White with a touch of blue in it! :person_facepalming:
But then itâs not meant to be a latrine light now is it!
Not very flashlight related but assembled my 3D printer and of course I will print some flashlight related stuff with it. Some mounts or diffusers and lens caps for bigger lights.
Printing centering rings and spacers works great with 3D printing. Allows me to get everything perfectly centered and focused with little fussing.
Great Idea. I havenât thought about that. :+1:
Nice work KawiBoy.
I invite everyone that has a mod (no matter how big or little, good or bad) posted here or anywhere else on BLF to join the following GAW. It's closes in 13 days:
https://budgetlightforum.com/t/-/44727
Both of these lights have the same innards: Triple XPL HI 4000k 5A2 on Noctigon, with Carclo 10507 optics. Driver is DrJones H17F. Both are running on Samsung 30Q 18650. All parts purchased from Mountain Electronics.
The one on the left is a Jaxman E2L host. Entire build took about 45 minutes. Assembly was fairly quick and painless. Only issues were the driver wire hole was too narrow and needed drilling, and the emitter compartment was too narrow to fit a triple Noctigon. A minute with the drill took care of the wire problem and 20 minutes with a small handfile on the edges of the Noctigon took care of the other problem. These are beautifully made hosts.
The one on the right started as a green anodized Convoy S2 plus host.
To improve these lights more I think I need to get some heat transfer foam to cram into the driver compartment. Would be nice if I could get better conduction of heat to the heat sensor on the H17F. If I had that I might be able to run these lights at max FET without risk of damage. (currently I have the Jaxmanâs double-click mode set at 2nd highest FET setting, and the S2+ set at 3 amps)
Tailcap spring bypass and direct drive on a FourSevens MMU-X.
tried dedoming my 1 and only xhp50 led
failed miserably, about 40% of the phosphorus lifted with the dome :person_facepalming:
Put a nichia 219c and a qlite driver with guppy drv into my single mode ultrafire c3
