Hmm, you guys make me think about modding my old BLF SD10. It still is a nice clean design. And there’s Soshine 32650 batteries around now (this link has a feedback that measures that in a Opus charger) that measure 7000mAh and probably perform better than the old Trustfires.
I finally received a couple of Convoy S2+ 18350 tubes that I ordered. It turns them into an even more compact EDC and my Luxeon V triple still draws 14 amps from the very impressive Keeppower 18350, making it ridiculously bright for its size.
Filed down a #14 nickel-plated brass finishing washer tonight. Thinking of attaching it to my clear E07.
I don’t think the E07 really needs a washer to prevent accidental activation as the light is big enough it doesn’t move around in the pocket much and the button is small and flush. However, this washer would provide a little more protection and would make it easier to find the button by feel when reaching into a pocket.
The washer slightly overhangs the flat part of the light around the button. If I end up gluing it on I’ll try to fill up the gap so the lower edge can’t get caught on something.
That would be interesting. Not sure if I've seen that for a flashlight before? Are you think'n made from soft plastic that has a flexible all one piece connection between the 2 caps?
pritty much, even PLA if push comes to a shove, end of the day there’s plenty of different velcro straps about. havent fired up the mind Blender3D yet. (costs a bit for the rubberised filoments, and then theres setting up the machine).
tbh i’m surprised the torch manufactures don’t do silicon injection moulded versions, is a very short design step.
I guess I've seen this before for binoculars. I got one pair with separate cup protectors and it's a nuisance, but if they were connected, and better yet, connected to the neck strap, it works well. For a flashlight, not sure it would work well connected to a lanyard maybe...
Lens cover?
I would try this
30-69MM Transparent Rifle Scope Lens Cover Flip Up Quick Spring Protection Cap Objective Lid for Airsoft Gun Caliber HT37-0072
My idea is to use a diffusion film on the cover to change the beam of a GTmini from throw to flood.
But I think DC fix is not enough. I need more a lens structure or pebbled on it.
Any ideas?
I suggested this in another thread I think DC Fix will be enough, have you tried? Every time I have used DC Fix on a thrower it totally kills the hotspot. It wont give you a super wide beam but it will blend the hotspot into the spill quite a bit.
Do you plan on putting the DC Fix over a 2nd piece of glass? It’s pretty thin. There are more thick “vinyl” feeling alternatives that may work better if you dont use two pieces of glass.
I got one of these same covers from Kaidomain for my Jaxman Z1, they are pretty cool.
Totally mind boggles me why someone would buy a light designed for throw then go out of their way to kill the throw…why not just buy a different light?
