Yes. 7135ās have three pins: VDD (positive input), Ground, and Out (low level / negative output). When voltage is supplied to VDD, the Ground is allow to flow to Out* (restricted to ~350mA). When voltage is removed from VDD, current stops flowing. By pulsing VDD (via PWM) you can vary the effective (not actual) current being sent to the LED. If you use the MCU (attiny13a in this case) to supply a 10% duty cycle PWM signal, the 7135 is enabled for 10% of the time. Over the course of a second, youād get 350mA for 0.1 second followed by 0.9 second of no current flow. Of course we use a much faster frequency than 1 Hz (Hz is cycles per second)ā¦ more like 8 - 16 kHz. Because of it switching so fast, our eyes usually cannot detect the on-off switching (unless a lower frequency is used) and we just see the average state of the LED, so we see it as if 35mA had been constantly applied to the LED.
Iām sure there are some nuances here that I may have mis-stated, but thatās the gist of it.
That made me wonder how this light level compares with trits. And the level is even lower! My integrating sphere could only just measure it, take it as a ballpark number but my LT1 measured 0.001 lumen output on the aux leds alone (switch led off).
Nitecore D10 anduril (14500 powered, sort of a mini fw1a)
Hardest part wasnāt the custom driver, it was sourcing the 3 hosts I purchased. This particular one was NIB and I paid a good bit for it, I was also thankfully able to scrounge 2 more used ones for a much better deal.
Luxeon V2 5000k
Oshpark boards in the new black fr4/clear mask (ugly, stick with purple!). FET+1, uses GT Mini FW target.
I only have 1 super old Efest 14500 for testing untill my li ion wholesale order gets here next week.
I donāt hate the black/clear but IMO itās kinda boring looking compared to purple (itās what oshpark is known for after all).
I think itād look better with a hatched ground pour instead of solid Cu. If I run across any more hosts and need to order more boards I think Iāll update it so itās prettier.
I also donāt like how hard the silk screen is to read with this color scheme.
This is the first reflector in which Iāve actually been pleased with the luxeon v2, LOVE the emitter behind a triple optic but IMO the beam from a reflector was lackingā¦ Not in this case, itās perfect!
As to the plain body, Iām really hoping to find a Balder HD1
Awesome! I am willing to do that in the one I bought a while ago, but havenāt ordered the driver yet!
Did you just swapped the driver or did you have to do any trick inside the pill (because of the wires,etc)? If that is the case,fo you have any photos that may help the mod?
I think it has to do with the reflectors depth:width. I tried them in an S2+ with OP shorty 20mm reflector and an Olight S15 (also very short overall but Ć=20mm) and both of them were ringy and had a pretty strong tint shift from spill to Corona to Hotspot.
The D10 reflector (also Ć=~20mm) has a much better depth:width ratio, Iād guess thatās why.
Also note the centering ring setup of the D10 keeps the reflector quite high off the 3535 emitter (originally XR-E).
I would bet the issue is centering height, then, if youāre getting rings. Thatās been my experience, anyway. Whatās really odd to me is the tint shift, as I never see that at all with the Luxeon Vs and the V2s are a close second there, at least in the lights Iāve had them in.
Nickel Boron?
Actually Iāve been reading on that just today and thought it would make a good surface finish for a flashlight. Itās interesting to see it was actually used this way. Could you please share your thoughts about it?
Not much of a mod, but hereās what I just did. Weāll see what it does tonight.
A $0.59 bowl from Target. I think it would be better if the bowl was a little more translucent. I drilled it out with a 2-1/2ā hole saw and trimmed the edges a little with an Exacto blade.
