Hi, Newlumen .
Thank you very much.
Your opinion served as a reference very much.
Hi, Newlumen .
Hi,
Lumintop ODF30,
Does the side switch LED of Lumintop ODF 30 light up?
When do LEDs turn on?
Best regards.
Those discharge rate specifications are a lie. Period.
Efest rewraps cells from OEMs. Nothing wrong with this, but they like to inflate the actual OEM cell specifications in a twisting, consumer misleading way, and on top of this try to charge you more. No way Efest.
I second Newlumen's cell suggestion but please check these AliExpress vendors' offers with a much cheaper shipping and handling quote to Japan (cells are blue wrapped but they're equivalent):
Cheers
Love my r50 pro seeker LE
This is our family go to work horse for around the house.
Stays in the kitchen cabinet in its charger always ready to go.
Nice size and hand.
Olight perfection on fit and finish, if your into that kind of stuff…
Hi,
I’m sorry to bother you.
I bought the following products at Banggood.
I have a question to the following products.
Lumintop ODF30 XHP70.2 3500LM 6Modes
Brightness Power Indicator LED Flashlight
I have to 5-questions.
Please answer in detail to all the questions.
At first, please watch the photograph of the URL.
http://www.lumintop.com/wp-content/uploads/2018/03/20180315061816_66180.jpg
(1)What kind of situation is output/mode shift?
(2)How do you operate output/mode shift?
(3)How does the indicator of the switch shine?
and
I locked-out a flashlight.
However, the indicator in the switch does not change.
As for the indicator, the lighting does not flash on and off, too.
(4)Is not the problem that the indicator does not light up or blink?
I think that the indicator is broken.
and
Capacity of the battery decreased.
(5)Is not the problem that the indicator does not light up or blink?
I have never watched the light of the indicator.
I think that an indicator is broken.
At first, please answer a question.
Please check the correct information.
I want to know the answer as soon as possible.
Best regards.
Okay, I will try to take these one at a time.
One click will turn the light on in the last brightness it was on. Single clicks after that will progress through the LOW, MED, HI. Double click while ON in any brightness to get to turbo. Single click gets out of turbo and back to the last used brightness. Long press to shut off from modes or turbo.
Instant access to turbo is available with three quick clicks from off.
The indicator light will only shine when the battery gets low in voltage. Plugging the light in will charge the battery and start flashing red and when the light is fully charged it will turn green.
If you locked out the flashlight you can unlock it by untwisting the tail cap and screwing it back in. That will take the lock out off. When it is in lock out you still have the option of using a momentary press of the switch for low mode only until it is unlocked.
I hope I answered some of your questions.
Hi, toddcshoe.
Thank you.
However, the Lumintop ODF 30 does not have a function to charge.
When the indicator lights up is it only at low voltage?
Will the indicator light up when output/mode shift is set?
Will the indicator light up when Lock-out function is set?
Best regards.
Please tell me about Lumintop ODF30.
Please look at the image of the following URL.
When output/mode shift and Low pwer indicator and Lock-out function is chosen,
it is written that the indicator of the switch turns on or it flashes on and off.
I do not understand the meaning of Output / mode shift.
Please tell me in detail.
(1)Output/mode shift,
Does the switch indicator light or blink?
(2)Low pwer indicator,
Is the switch indicator lit or blinking when the battery is low?
(3)Lock-out function,
At what time is the indicator on the switch lit or blinking?
The flashlight will flash.
However, the indicator inside the switch does not light up or flash.
Is this normal?
Is there the problem?
(4)When a light dims, a light flashes on and off.
Is this normal?
Best regards.
You are correct sir, I apologize. At low voltage the red light on the switch starts to flash to remind you to recharge.
I do not think the light on the switch blinks or anything on mode changes.
When the light gets too hot on turbo or high the light will decrease output. The flash you are seeing might be the flash it makes when going into lock out mode.
