Wow hope you enjoy using the light later! I searched everywhere, seems to come with the standard gift box and manual, with charger and a 10440. Seems like this special colour is intended to be given as a gift.
Yes, it comes in a nice box, and what you said is what I thought, that it’s meant as a gift box.
The battery is just a gray TrustFire 10440 (TR10440), and it’s only 600 mAh. I think it’s unprotected.
The charger is not bad so far, based on one usage. It charged the 10440, and ending voltage was about 4.19V, so it’s actually has a better terminating voltage than a TR003 p4 charger that I have.
Modes are H~~M>LStrobe~~>SOS and it does momentary, and then if you click all the way, the mode is set. The tail switch is kind of too deeply recessed into the tail, I think. It’s hard to press.
Okay I found my picture of my (left to right) LD01, CQG S2, DQG AA, and a Liteflux LF5XT. The LD01 uses 1xAAA. The other three use 1xAA, and I use a 14500 in the CQG and DQG.
Thanks for the DQG AA suggestion, and the effort for putting up a picture comparison! Though it’s small enough, I’m still looking out for 10440 lights, for the bodies to be as small as possible, and still having a good output. The main motivation is to find smaller lights with almost the smallest and yet common batteries around — AAA. Or 10440 which doesn’t seem to be popular.
But this DQG AA is amazing. I have known it long ago, but I never really checked out its length as I’m focused on looking for AAA or 10440, so I dismissed it seeing that it is AA. But at 72mm it’s so so short, and comparable to some AAA lights. I had previously another thread here which I tried to find as short as possible lights, now it’s going into the list.
LD01 takes 10440 batts just fine…and it is an awesome little light! I am running the marsfire protected 10440s…but I had to ream out the LD01 body because the protection circuit OD was just slightly too big.
I have 4 batteries and rotate them often, then charge them at once using the i4 intellicharger. When 4 are charged at once, it supposedly charges at 300 mAh, which I understand is about the max load they should be charged under…someone correct me if I am wrong.
Found this company that sells the Balder BD-0 here rebranded. I have carried mine for over two years everyday. The 10440 they sell have worked very well and cut off at 2.85 volts if you let it run down. I have also started using blue protected Trustfires for over two months. The Trustfires are holding up very well.
On high the light puts out about 230lm and can be held for 2 minutes before you have to put it down. On low it runs about 80lm for just over an hour and remains only warm.
The HF is a no bones 2” keychain light that comes with 3 specially made Nuke 10250 cells that allow it to output over 500 lumens! In short burst of course because it makes a lot of heat! It comes with a 10440 battery tube as well, in which nothing compares to the Efest IMR10440 cell. The Efest 10440 performs about as well as the Nuke, allowing this little direct drive XM-L2 light to start up at some 3A!!
I’ve used these cells in 4 high power lights for months now, including the one always around my neck in my custom made Titanium light from Photon Fanatic. I carry 2 spares with me all the time as well, cause you just never know when some crazy white wall is gonna need killing in a bad way!!! Here’s the custom made Ti light with the spare Efest cell…
These aren’t exactly budget lights, but nothing else really compares.
I made this poster for application on a T-shirt, enjoy!
The black 10440 protected cells are too long for most of my lights. The only one they fit in is my Thrunite Tis, which is quite bright and quite hot on the 10440. But they wouldn’t work in my Tank or my Olight. Are the non-protected Efest batteries more usable in these other lights?
I love mine too! The ONLY thing missing here is a moonlight mode. Got an i3S coming that ‘may’ end up replacing the A3…we’ll see. Glad to hear the i3S works fine with a 10440, hope the moonlight mode doesn’t get too bright with that much voltage pushing it!
I have been dabbling in small flashlights recently and here is what I have to say:
For normal basic EDC I have a Blackshadow Eva with a Energizer Ultimate Lithium, simple, basic one mode, cheap, battery life so far is great!
I recently bought my wife a Tank 007 Tk-703 and it has a grey UF 10440 and I am actually quite impressed. Tail switch which is nice and it throws pretty decent for a little light!
I have a Lumapower LM21 with the XPG2 and I am quite impressed with it. Tail clicky which I like. I had troubles initially with the switch but with a replacement it works fine and is BRIGHT (420 claimed lumens) but that is with a Efest 10440. It is mostly all flood, but still “throws” pretty good because of the sheer light. UF grey 10440 is too long but can be made to work with a paper clip spacer, but for the highest mode a Efest is needed anyway because of high current draw.
The i3S is a little jewel of a light…i carry an Eneloop and an Efest 10440 to have all the options. Put it on your cap to make an excellent headlamp! :party:
You can also use an Ultra(p∞p)Fire for an intermediate option.
I got my A3T in a couple of weeks ago. I popped an Efest in and that little son of a gun started out at 400 lumens and ended up about 250 otf after 30 seconds. It was HOT! I like this little light but do not recommend using an IMR cell in it. I don’t think it would last very long.
