Thank you ‘Ouchyfoot’ for the excellent description! Right, I knew that with the ICR I would loose medium mode on the Eagletac d25c (it does still retain low) I just didn’t know that it was called direct drive. I will have to keep this in mind. I might use a ICR for tactical use e.g. night in the city and IFR for longer use e.g. camping.
Would anyone suggest a good IFR?
Will the i4 intellicharger charge an IFR? Does it still have to be 3.7v to charge it?
I have many chargers, and the MP2 is the only charger I use for RCR’S (16340) batteries. The 250mA charging rate is ideal for these smaller capacity cells. The fact that you can switch between 3.0v and 3.6 v makes it extra handy. Plug it into the wall, or a USB port. This is a safe and dependable charger.
I think I’m set on the MP2 charger because I like the benefits of accepting all rcr123a chemistry’s. I am trying to narrow my battery search down so that I have the best batteries. Tell me what you think.
(AW RCR123a Protected 3.7V 750mAh $9.5) VS. (Nitecore RCR123A 2-Pack 3.7V 650mAh $15). And I had a hard time finding IFR batteries in a name brand? (Tenergy RCR123A 3.2V 750mAh LiFePO4 $7.5)
Thank you! I read that AW123 protected Overcharge protection is at 4.35V - Overdischarge protection at 2.45V and Advertised Capacity: 750mAh, Measured Capacity: 563mAh but I’m not sure how many amps it supplies or how many recharges they claim. The Nitecore123 calms to supply 4amps and 500 recharges but i can’t find anything else as far as specs. I’m told anything less then 2.8v you start impacting battery life. Quickly searching I heard tenergy might have problems :-/
Reference Links:
Review on AW123 here if you scroll down his blog a little. I’m still trying to find a 3rd party comprehensive review for nitecore123, although they do give a lot of information on there website.
Far fewer options out there in IFR. Their lower capacity usually means people only use them when the light really can’t take the higher voltage of other options. I’d trust the Scaru’s opinion on these more than mine.
Looks good. I guess it is between nitecore (2 for $15) and solarforce (2 for $11). Leaning towards solarforce now. Good performance and cheaper.
I heard size might be a problem with the Solarforce. I’ll be putting it in an EagleTac d25c… might be hard to make sure they fit given I haven’t bought it yet.
Solarforce DIA = 16.7mm, Length = 36.1mm
NiteCore DIA = 16.6mm, Length = 34.8mm
Tenergy DIA = 17mm, Length = 34.5mm
AW DIA = 16.62mm, Length = 34.29mm
*EDIT: EagleTac d25c compatable battery size: Diameter : 16-16.9mm, Length : 34-34.9mm So Solarforce wont work for this flashlight. Do you have any thoughts on nitecore vs Aw
AW or Sanyo are both good. The Nitecores use Sanyo cells. Sanyos are a little fatter, and I have a couple lights the wont fit in. AW fit in every light I’ve ever tried them in.
Thanks for the info and links! Does anyone have info on the trustfire rcr123a. I have found some that are priced very well and am curious to there quality/performance.
