I would be too. I posted a picture above so the outer and inner spot IS round and it's just that outer TIR artifact, aka. spill, I think, what some commenters find detracting.
I just pulled mine out and see the “square bottomed” spill as your pic shows… looks like a “flat tire”
— thanks for that effort Nach!
Sorry to make your confused.
The first stocks of C3 has a square spot. But our tech guys has solve this issue by upgrade the TIRE to make the spot round rather than square.
Check Nachtfeuerzeug comment on #19 for more info
OK, I sent an email just now. Are you suggesting I can get a replacement? I own a C5 too (great little light!)
Thanks.
That depends on which verdor you bought from.
This is the shop I charge: https://amzn.to/38EnK7G
Anyoe has bought the first batch C3 from the above link, pls PM me your order number for after- service
Hey great service here! I DID buy from that Amazon shop and am sending you my order # right now!
Thanks Wuben!
C3 is on lighting deals now for 15% off plus 5% off coupon, total 20% off.
Ended in 13 minutes.
Get a new one now to save big
Link: https://amzn.to/38EnK7G
Perhaps TIR was meant?
Olights i1r2 does the same square spill. I thought that would indicate a good alignment of LED and optics.
Anyone has bought the first batch C3 from the above link, pls PM me your order number for after- service
Just a shout out here to Wuben for standing behind the MANY great lights they sell. :+1: :+1: :+1:
I personally own a C3 (and smaller C5- 14500) bought this last year. BOTH nicely designed lights with excellent finishes (several colors). The C3 had issues with overcharging (see this post a few months back). It also had a slight misalignment problem with the reflector/led. As I bought the light on Black Friday I figured I (kinda) got what I paid for, BUT when I asked them about it they INSISTED on replacing my C3.
In fact, SEVERAL Wuben reps contacted me to insure I was happy. Very professional, honest, and straight-up about the C3 problem and wanting to make it right.
I was a fan, and now I’m a BIG fan of Wuben… and I can see more of their lights in my future.
I got the Wuben C3 from Banggood before (which has the overcharging issue, which I am more concerned about).
I also did notice the "flat-tire" beamshot when shining the C3 on a wall, but I think not too noticeable in actual use..
In my Youtube beamshot video below, I made this comment in the description, about the "square-shaped" beam pattern for the Wuben C3:
1) reflector:
Wuben L50S uses SMO reflector
Wuben C3 uses TIR optic
(comment: when at near distances up to around 2 meters or ~8 feet away, on a white flat surface, the C3's beam displays some square beam pattern)
I'll try to make another beamshot of the new Wuben C3, IF I can be assured of getting the new version (I am unable to order from Amazon).
Nice to see your comparison beam shots d_t_a!
I had a delivery of the corrected design C3 get screwed up by a new postal worker who couldn't find the mail box so hopefully, I can get some beam shots by tomorrow.
The new light arrived early today. The protected Wuben battery was at 3.6V when I started the cycle and terminated at 3.9V.
Concerning current draw, measurement was 3.1A & >4A with a 25R.
At ~4V on Wuben battery, I measured 1200 lumens.
With the Samsung 25R, it produced >1500 lumens.
And finally, the new TIR beam pattern is round. Both the spill and the hot spot.
I haven't found a single LED, clear, tight beam TIR without optical artifacts but this new one is good.
I'm charging one of the unprotected Samsungs I used in the previous post, at the moment, and will report on that.
My meter was still showing a 0.008mA current but the battery charged up to 4.16V.
Got my replacement and can confirm everything Nachtfeuerzeug said.
My voltage ending was 4.17 , my USB tester only goes out to .00 and it was at .01 when I pulled it.
As far as beam, she is nice and at least on my sample it is a tad warmer looking.
Mode memory also works well.
She’s a beast for the $.
Thanks to Wuben for making this right.
Later,
Keith
Picked up one, used discount on amazon, $20.00. Charges correctly, bright with round beam.
Ordered a C3 off Amazon a few days ago and it arrived today.
I can also confirm the onboard charging issue seems resolved, my C3 was left plugged in for several hours while I was out running errands, when I returned the charging light was green and the supplied Wuben battery tested at 4.17 volts.
The square light pattern was also absent from my light.
Thanks Wuben for making a very nice budget light
Thank you guys for the support.
But some customers might not take my honest as a rgiht thing. I reply everyone for the replacement and give the best sulotion I can offer.
However, they take this info and get me to 1 star, check the review here: https://www.amazon.com/gp/customer-reviews/R3A6MQCQY2WA3F/ref=cm_cr_othr_d_rvw_ttl?ie=UTF8&ASIN=B08LG64XBV
Now, my sales drops like crazy, if this is your purpose, you have make it succeed.
I'm not regret even now "harvest' a one star review for being honest and talk as much as I can here. But this should not be the weapon you are againt me.
For WUBEN supporters who got the new batch for replacement or order the new batch, could you help me to fight back?
Submit your honest opinions to Amazon and let others customers know the ture fact.
Thank you!
Thank you!
What makes even frustrated is that he is even not a verify purchase. Now I'm thinking it may come from the sneaky competitor who grabs every chance to attack in such a disgusting way
