I have the ManaFont UltraFire 3-Mode, I'm pretty sure others have said its better than the DD drop in.
L2 and L2P are nearly the same apart from the anodizing, Id go for the L2 with the MF UF drop in but I might be bias because I already have one.
I ordered both the OP and smooth reflector drop in from DD. The smooth
one came yeasterday. Normal quality, 5 mode and just as bright as all
other XML.
Looking forward to receive the OP version.
Whats as bright as other XM-L mean to you?
I have 2 WF-501b's both with XM-L emiters, they are only half as bright to they eye as my UF MF drop in.
They are so disappointing I am just going to give them away, I feel I'd be ripping anyone off if I tried to sell them.
The ones I bought aren't as good as others here received. I'm surprised some of you are seeing 3.5A draw. On an Xtar 18700 mine only pull 2A where the same light with a UF XM-L drop-in pulls 2.7A.
Side by side comparison the DD drop-ins are noticeably less bright.
All my dino's XM-L's (with in 504B bodies) were around 2A. The only exception was the single mode (ordered a 5 mode) that drew 1,4A. Funny tho.
Even R5's single modes were preforming lower than wanted (800-850mA but those would accept 8,4V apparently. Never tried though.)
At one time i was happy to have recieved one with an off center XM-L. Turns out it the star was 12mm one so i took it out and put a 16mm in it. I always wanted a 12mm star XM-L. Now i have it. :) Perhaps i will try it in my C3 SS with stock driver.
I have no equipment to measure brightness, so I cant give a figure. I measured the the amps
which was 2, so its not driven very hard.
But for the price paid, nearly 9$, you get a XML T6, a driver, a pill and a reflector, so if you mod, as I
do, it was a good deal. A driver change to 3.5 amps, and it will be just as bright as any from MF
ezarc: Nautic:I ordered both the OP and smooth reflector drop in from DD. The smooth
other XML.
True dat! I just wish we had more choices among US sellers and free shipping too. Can’t have everything, I guess.
My drop in, as was reviewed in post #1, came today. 5 mode and smooth reflector
(not OP as advertised). Current draw 3.5 amps, so its another driver than in the
one that came a few days ago. All told a good buy for close to 9$. Most XML T6
cost that much by itself.
