Thanks Guys!
The low Vf should substantially increase the efficiency at higher currents even it the LED isn’t actually brighter compared to the current XP-Ls.
You probably all know this, but it will be much easier to make a single cell light that stays in full regulation at 3A+ for the entire runtime (currently very few lights, mainly from Zebralight and Armytek manage to do this).
Very good point. I should have known that, but never thought of it that way. I got my head in the high amps/max output mode most the time, but that kind of usage on 7135 based drivers, for example, is pretty darn good.
I just looked through the places I know to check and could only find 80cri. Thinking this could make for a pretty nice EDC LED with a bit more power then what I have now.
Well crap, I don’t know why the ones I had died on me then. The remaining two that I had are in route to someone to test…it may have been a crappy reflow?…but it was on two different mcpcbs and they both have XP-L V6s on them now and run fine…so I don’t know.
dj, I'm not sure what was going on then because I have run these very hard repeatedly with no signs of thermal stress. Maybe yours had extra low vF? Did you measure the current draw or forward voltage?
Like 2250-2300( v6 sample, Mouser breed, kit 51), yet it runs hot like hell…i aint quite sure how long how it will hold those on a long term base
G3 isnt much of a high amp long term champ, they die pretty fast( personal exp)
The most annoying is that they dont dedome, thus makes them useless fro throwers
I'm only seeing 1500-1600 at startup OTF, but that's non-AR w/ an OP reflector. 1400+ after 30-60 seconds. I'd believe 1900-2000 LED lumens if you could keep it cool enough.
Nah, I don’t have a very good meter and I’m doing (what I consider to be) “ok” with a meter if I can measure battery voltage, lol. I’ll let you experts handle that end of it all. I probably need to go back to the drawing board and start off with this to learn about current, lol.
I’m going to lean towards crappy reflows, especially if RMM is running one dd with no problems. That just means I’ll have to stick with getting them from RMM already reflowed, lol…which is what I normally do any way.
The reflow may be part of it but a poor mate or a bit too much heat sink compound can be worse than none at all, the stuff’s supposed to fill the gaps where the metal surfaces don’t touch rather than create a film between the surfaces. Extreme current exacerbates the effects of thermal blocks. DTP copper is the best initial step available but that isn’t the whole picture.
If you’ve modded you’ve probably killed a few LEDs, at least yours DJB died in the persuit of knowledge. Every new led throws us a curve or two, the fun is in finding what they’re good or not good for.
I gave it over 15 amps but it still lived! It was hurt but still lit up. At over 70W of power it literally cooked the dome right off. This is one way to dedome them I suppose!
I am amazed at just how much power this thing can handle. It didn’t even peak until 10A!
From a cold start it made 2450 lumens @ 10A! Hot it was 2280 lumens!
Remember this is only a V5, they have V6 and maybe even W2’s on the way that could net an honest 2500 lumens from a single die LED!
Be sure to check out that thread, I want to standardize my test setup before I release anymore LED tests.
