So what’s the advantage of this one vs a buck regulator like this one: link
They are both buck converters and work similar. It is basically a matter of quality and output level.
The one on banggood is a lot harder to work with and I am going to guess not as accurate.
The LCD screen on the 5015 is an amazing tool that makes using it far more plesent.
The biggest difference though is the 5015 is good for 50v and 15A, the one on banggood is only good for 36V and 6A.
If you don’t need more then that, then they will both do the job. Although they also have cheaper dp and dps options if you don’t need as much current.
Higher current requires much better components and design.
I have one of these currently. I agree the screen isn’t so convenient.
So if I don’t need as high of power, this one will be just as good?
Yeah, that would work just fine. I have that model as well myself and it works great. That said the firmware is nicer on the DPS series but nothing that major.
You can pick up the DPS series for a few bucks more and if you send him a message he might knock the price down a bit more if you mention BLF : https://rdtech.aliexpress.com/store/group/DPS-Programmble-control-power-supply/923042_508466030.html
Did you detail the observable firmware differences in a review somewhere? (I’m interested and don’t want to make you type it twice)
edit: found on BG:
Yeah, it was posted in my review but the above quote is the gist of it.
That is one thing I forgot to mention, the larger 3012 and 5015 allow you to charge batteries without a diode, which is much much better (it allows you to see the actual voltage of the batteries instead of just what the supply is putting out plus the diodes have a voltage drop as we know.
The ability to charge batteries with up to 15A is quite a nice feature to have.
You can look at the extra cost as a high powered battery charger.
So, I am considering ordering the DPS 5015. I have never used AliExpress. Do you guys preload a card to use with them? If so, what kind of card does it take?
They are secure enough that I just use my normal card. I mean aliexpress / alibaba is one of the largest companies in the world, I am gonna guess that they have halfway decent security.
I did not buy one of these, however I have in the past been greatly disappointed with these type of supplies due to my overly exuberant expectations.
Don’t expect to input 40V and have continuously variable output voltage from 0V to 32V AND be able to draw 12A along that whole range.
I am guessing here, but I’m thinking that you could possibly get that 12A only IF the input voltage is no more than say 1.5 times the output voltage.
Even that 12A might be an exaggeration.
For me, this could be useful for some portable power. Mate this with an 18V drill pack, and you could do all kinds of neat things with it.
I thought the same thing when I first ordered them but to date they have worked exactly as advertised. I have nothing that can use 30v @ 12 amps to test it with but on my smaller unit that is powered with a 12v power supply, it has no trouble providing the full 5A it is rated for up to 11v.
It most certainly DOES provide 12 amps no problem at all (well besides the shunts and mosfet getting warm), I do it all the time when testing multi-emitter lights among other things.
I have yet to have it not do what it should under any circumstances.
Yeah, 5A out at 11V because your input is only 12V
What I’ saying is that if you input 30V you would not be able to get anywhere near 5A out.
All I am saying is this is not a substitute for a variable bench type power supply that can provide the amps over it’s entire voltage range.
I still do not have a decent bench top power supply. I am thinking about getting something like this to make a portable supply.
You misunderstand, I have 2 units and both function exactly as they should. 1 with a 12V input and the other with a ~40v input. I have no problem getting whatever voltage and amperage I want no matter what the input voltage is (as long as it is over the output naturally).
They actually make a GREAT substitute for a bench power supply and that is exactly what I am using them for.
The only thing I have not been able to test is both high voltage and amperage as I have nothing that can pull that much power.
Yeah, I can see how folks might interpret the operating ranges to mean that the product can operate in both extremes simultaneously. The product page does warn about it, but it isn’t stated in a clear manner. One has to know a bit how these budget buck circuits work to know that it stresses them to have too much voltage overhead on the supply side. You got to pay big bucks for what you are expecting. That is why mine will be powered by 1 to 4 DPS-600PD’s. That will enable it to be powered by 12, 24, 36, or 48 volts. Actually, much more choices will be available as they are being modded for variable voltage output.
I've also taken notice of the abundance of controlled user friendly dc-dc converters available recently. Search "DROK constant current" on amazon and you will get something almost like (or maybe the same as) these as well as a number of other neat things, like for example this:
https://www.amazon.com/DROK-Adjustable-Converter-Stabilizer-Protective/dp/B01FQH4M82
or for super cheap (no idea about quality on any):
https://www.amazon.com/Converter-Regulator-Step-down-Transformer-Adjustable/dp/B00GZG7X9Y
Or even smaller ones without the displays that can even be used in a roomy light build, but still have pots for both voltage and current limits (the latter of which could be replaced by a remote knob for analog power control of a light).
quoting:
NOTE: 1.You must make sure that the input voltage is 1.1 times higher than output voltage. Under large current circumstances, pay attention to heat elimination.
But maybe that doesn't cover the whole point.
These seem like a great deal for what they're asking, no question. I paid several times the price of this setup for my 30V 10A linear supply.
Be careful with the cheap power supplies for these---remember: the only thing keeping you from the mains is that power supply; this buck converter is not isolated. I wouldn't want to be touching probes or live equipment all the time that is powered by a questionable AC/DC power supply. Spring a few extra bucks and at least get a Meanwell or other mainstream (and hopefully listed) AC/DC supply to power this with.
Depending on your needs, a laptop supply should be pretty reliable no? (maybe they don't handle abuse such as shorting well?) Often available for free.
This is not true (at least for the 50V/15A DPS5015). I did some quick tests when mine arrived and it did not have any such limits. I tested it at 49V input with output voltages of 44, 36, 24, 12, 6, 3V and currents 15, 12, 8, 4, 2, 1, 0.5A (all 42 possible combinations of both) and it worked fine, with efficiency between 90-98% for nontrivial loads (over 20W). The efficiency measurements are probably +/-3% since I didn’t have time to set up more precise tests.
So you are saying that you can input 49V and draw, say 6V, at 15A with this thing?
If that is true, I am very, very surprised! I will have to consider the DPS5015. As some others mentioned, being able to go over 42V is a must for some of the higher power COB emitters.
Yes, it was about 93% efficient at 6V/15A and about 87% efficient at 3V/15A.
Ditto, as I said above, I use this to test basically all my flashlight builds before putting batteries in as it allows me to see exactly what is going on. It REGULARLY sees the full 12A it can deliver at ~4v. Sometimes for extended periods in order to test thermal regulation on the light. All of this with a ~38V input voltage.
Besides getting a little warm it has shown no issues at all over the few months I have been using them.
