SkyRay worth my time?
Yours looks better than the 7 led skyray king I bought 3 years ago for 38$
My driver was sticky taped to a thin metal “heatsink”.
But for a first light, you are following in the footsteps of many of us.
If it gets to hot “like mine did” you can put cooling paste on the heatsink.
But now that you have seen what 19$ buys, try saving a bit more and you’ll have so much more joy.
Try Nitecore, it is the brand that I love so much.
Sure you’ll pay way more, but there are groupbuys on this forum that are really worth it.
Welcome to the forum and embrace your new addiction :smiley:
For the price it is not a rip off, you are getting a good amount of lumens for the price. It is also not a great deal either.
The real issue is cooling, it is hard for the LED’s to get the heat to the body. Some thermal paste along the lip helps.
Shameless plug - I have some drivers for sale that would take care of the driver issues along with a better UI. They also include thermal management although without a shelf it will not be all that useful.
I am fairly skilled in soldering/hobbies type stuff. I have many other lights now (s2Baton, EC4S, C8S, and a S41 and S2+ on the way) figured I’d ask about this one as I rarely use it not that it is “sub par” haha. Thanks for the info so far guys!
Been looking at drivers on mountain but unsure of what to do about LED’s as I don’t want to flow 7 my first try AND it’s an aluminum PCB anyway.
I’ll give it a shot. Thank you.
Welcome to BLF
I reflowed 4 in a similar light with XML2 NW
I put the shelf on the smaller of our gas stove with a small piece of solder I cut on the board.
When that became fluid I removed the LEDs with tweezers.
There was a fair amount of solder left on the pads and when I had +/- figured out placed the good LEDs and again used the gas stove for heating. They set themselves and this was so much easier then soldering wires
If it is within the Amazon return policy, yes, at least imo.
I would use the $19 and save some more to pick up a Supfire M6. Then you would have a light built like a tank, better in every aspect. You can also tinker a bit with the M6 to increase output and not have to worry about unknown quality LEDs, heatsinking, bad threads, etc.
I bought exactly (I guess) this light a couple of months ago and didn’t expect much from it, just wanted to own one of the “famous” SRKs. Here are the first mods and measurements I did with this light recently:
- before modding about 1800 lumens with Keeppower protected cells,
- added some thermal paste between MCPCB and the “shelf”-ring,
- brigded the printed resistor which Pilotdog68 mentioned and got about 2700 lumens,
- doubled the wires to LED-MCPCB and got about 2800 lumens,
  • bypassed the springs and added some solder beef to the tail PCB and finally got about 3200 lumens out of the fake XM-Ls.
Of course the light get’s hot fast and the tint is not the best, but this light has potential. Up to now this mod didn’t cost anything (apart from the solder paste).
Meanwhile I ordered genuine Cree XM-L2 LEDs and I am trying to get a fitting copper-disk. I will substitute the driver with a FET+1.
I guess there are some more lumens waiting for me …
Perfect light for Nichia 219b swap… if somehow possible.
I’ll give some of these a try. Thank you!
I don’t believe the Nichia 219 fit on a XM-L PCB.
Good idea!
Correct, I happened to get a 7x SRK that came with “XP-L” Clones. I am gonna put some high CRI LED’s in it, just have not decided between the 219 or XP-G3.
I might even go with a mixed tint high CRI build, thinking some 3000k and 5700k 90+ CRI leds.
Very nice idea. However the 4000k nichia covers most of the spectrum. Check out this Adding Deep Red Leds for improved CRI and R9 the only missing part is the red and cyan spectrum.
I had an idea for same light of this sort with 2 red ~700nm leds, four nichia 4000k and one cyan. But it is a really complex build. :frowning:
Yeah, the 219’s are great as is, although I think I would go with XP-G3’s if I went mixed tint. I have always wanted to try a mixed tint light.
In theory by mixing tints it gives it a bit of a high dynamic range picture, is still is a picture, just more of it, hard to explain any other way. At least that what I have read about them.
Hpg3 has high cri also.
But are very rare. And very small number of places carry them.
Talking about the XP-G3? Yeah, I have a few of them already, I plan on playing with them as my next project actually.
Oh man. Too many ideas in here. Haha. Great input guys. I’ll post some progress pics when I get to doing things.
I’d send it back if you can, and put the money towards the Q8 group buy. I think you’ll be thrilled if you do.
Edit: even if you keep it, get the Q8!
Used a RMM driver with moon for my SRk, and thermal paste between shelf and housing.
Now I would go for a Narsil Q8 driver.
When I started talking about SRKs I got a bit overwhelmed by negative comments from people knowing how good they were.
I got lucky and received a few with the fake XML (LaticeBright) LEDs that actually give a very nice tint.
And I really love the flood of lights like this.
Yet after reading so much posts about how good a light like this actually can be we started the Q8.
In the first post there is a list of parts and the second post is for Narsil (the software)
You could make a very nice driver.
Idk where you live but Oshpark has 3 boards as minimum so maybe good to find two others for three drivers, Narsil ia about as sweet as it can be :wink:
well i bypassed the squiggly. and WOW what a difference, pics tell the story, ill try to get some beam shots tonight when its dark.
this was after it was off for almost a minute.
