...And as promised I'll share my opinions with you. This is the first review I've tried to write; also my first LED torch. And first didge camera and computer. Sorry for the disclaimers but it's important that you know to keep expectations on firefly mode. Here goes..
This is it http://www.manafont.com/product_info.php/saintfire-k25-xre-5mode-memory-led-flashlight-set-1aa2aa-p-7297, and Saintfires own site http://www.saintfire.com/. I've no testing/measuring equipment, and wouldn't know how to use it, so for most tech details I suggest you check the links; as far as I can judge the info seems accurate, though I strongly suspect that the claimed 230 L output is (very) optimistic. That said, I've been playing with testing the K25 with ordinary Duracells and there is the option to run it on 14500's if you change the "PCB"(huh? explanation welcomed); you guys would know far better than I if this would make any significant difference or not.
1) Delivery/ Box Contents/1st Impressions Etc.
From Add To Cart to Sign Here took six working days. No probs of any kind. Impressive; thanks Mana. The box itself is thick cardboard with a lift up lid and a magnetized front flap. Not as fancy as it sounds, but adequate for storage/delivery. You get a spare rubber switch cap (orange again), two O rings, a holster and lanyard. I have average hands for a bloke, and the lanyard is just the right size to slip on but not accidentally off again, but really big guy might find it constrictive. The holster is un-padded and single stitched but it seems adequate. Again it's an excellent fit for the torch, with three ways of attaching it to yourself; seems like design trumps build quality here, but it would do for me (if I ever use it). Note that no pocket clip is included, or operation manual, though the UI is simplicity itself
2) Build Quality/Handling
Initial disappointment is the wobbly tailstand. The switch cover protrudes by less than a mm, but it's enough to matter. Might be moddable; advice welcomed.
Build quality feels commendably solid, more so than either the Mini Mag or the Ultrafire 501A host that I bought by mistake, thinking it was a complete torch! There is a very slight, brief battery rattle if you waggle the torch vigorously, or rap it against your palm, but not significant. Threads are square (I think) and all lubed; they screw together very nicely and you'd have to work hard to cross them.
The head section threads are the only ones not anodized. One concern is that the four tube sections don't screw tightly together, leaving shallow grooves. This seems a deliberate design, but I can't help wondering what effect these gaps - about 1mm deep and wide, the photo is a bit deceptive - will have on waterproofing. And dirt collecting..
Despite the barrel ribbing, lack of knurling does make the torch a bit harder to grip than it might be. I find the "cigar grip" the most intuitive hold with this light. Anti roll collar and crenellated bezel are both discreet rather than aggressively functional. The bezel is just about right for an EDC, the anti roll could perhaps do with being a bit more effective, but it's a lot better than nothing.
3) Modes/UI
As per the spec, this is a 5 mode light. Low(10L) Medium(80L)High(230L) plus strobe and SOS. The output figures are the company's, and I suspect that 230L on max is (very) optimistic. Although to be fair, Ive been running the K25 on ordinary Duracells, and there is the option to use 14500's instead. But the brightness levels are certainly well spaced,. Measured from 1 meter away with a sekonic lightmeter, each level is almost exactly two stops brighter than the one before. With the meter set to ISO 200 and a shutter speed of 1/60th sec , low mode gives a reading of F1.4, mid = F2.8, and high reads F5.6. Sorry guys, I've no clue what this might be in lumens or lux whatsits, but maybe someone can translate.
The switch is a reverse clicky, so there no momentary on. Or off, come to that. A soft press of 2 secs or under takes you instantly to the next mode; longer than 2 secs takes you straight back to low mode. If you're already in low mode to start with, the longer press takes you back to it without going anywhere else, so I guess low mode is the only one where you can have a momentary off.
I have to say that cycling through the modes is effortless and instant. The switch is a bit sensitive and ocassionally I did it by accident, but it only takes a second to go all through and back to where you were. In this way you blinky haters can bypass strobe/SOS mode by simply not staying long enough to let it come on.
There appears to be no programmable memory. There was no manual, so I may have missed a trick here, but it seems that with the K25 you get what you're given. And whatever mode you click off from, it always switches back on in low mode. Takes less than a second to step up to max, but some of you may find this irritating.
4)Light output/Beams/Runtimes
The brightness impressed me immediately, but then I'm used to a Mini Maglite which sets a very low bar in this respect. What surprised me though, was the wide and very useful spill from such a small head, especially as the reflector is so comparitively deep, and appears smooth.
I haven't tested run times, but I can say that so far I've had iit on full output for about 45 minutes, mid and low a bit less, and so far there are no signs of diminished output. I'll keep you posted on this.
This is the bit I've been dreading. For a photographer (albeit film only) these attempts at beam shots are embarassing, but hopefully better than nothing. All exposures were on ISO 200 for half a second at F3.3. They are the K25 on low, mid, high, followed by the Mini Maglite on tightest focus. The door is 4 meters from the lens.
This gap here is an accident. As I've written all this, I have several times lost pictures and chunks of text by trying to make this look as professional as possible. I'm not gonna chance it again, so I'll fill the space here with this meaningless drivel. I lost half the review when I tried to preview it, so this time I'll just post, typos, ommisions and all. Hope y'all don't mind too much... Next shot is high mode.
I told you I like the candle mode. This is with the snoot fitted, bought from Mana at the same time. It's not dedicated to this flashlight, and I had to sand a mm from the inside. 2 min job.
And here without the diffuser. I confess both shots were deliberately over exposed by a stop because this shows much more accurately what the eye sees at the time.
And here at 1/25 sec with the K25 on med. Had to speed the exposure to avoid whiteout
K25 on high from 12th floor window. Too much light pollution/competition really.
You can just make it out, on the roof structure on the low rise block opposite. Target is about forty meters away from flashlight. Not as impressive as I would have hoped. In the shot below, the target area is a bit further, maybe sixty meters.
Sorry for the poor quality, my camera is pure auto focus and it couldn't see. In the shot below, the two trees are 71/2 and 15 meters away respectively
And the obligatory white wall(actually ceiling) shots to try to show beam pattern. The ceiling is about 2.2 meters, or 7 feet, from the lens. Here on high mode
...and below on low mode
Below with the Mini Mag and the Ultrafire 501A. I had a shot of the K25 in single AA format but couldn't get it downsized/transferred to Photbucket/uploaded here. Lost in translation.
And finally in 1 AA mode
5)Summing up
Well, I've certainly learned a bit, not least a real appreciation of all those who regularly write fuller - and better! - reviews than this one; these things take work, man! Hats off to you guys. And from now on,I'll treat company beam shots with healthy scepticism. Even without digital assistance, a generous dollop of over exposure can make a single AAA Mag Solitaire look like a TK41 (well, nearly). Also, sadly, I discovered how quickly the novelty of a bright new LED wears off leaving you hungry for more Lumens. But I'm NOT a flashaholic. Honestly. It's ok, I can handle it...Although that Ultrafire 502b XML T6 looks nice. 900 lumens! And it's only £18...
For a first LED light, I'm quite pleased overall. Things I like are (1) Solid build (2) Instant mode change response from soft press (3) Well spaced outputs (4) Splittable into single AA light.
I'm not so keen on (1) Wobbly tailstand (2) Tube sections don't screw tight against each other (3) No momentary off in any mode other than low.
Other points which might be significant for some (1) No programmable memory (2) No body knurling except a the tail cap, and that's pretty subtle (3) Anti roll collar works, but not brilliant (4) Top section won't unscrew - no access to LED or reflector. (5) Tailswitch would be very difficult with thick gloves (6) SOS cycle too slow
I realize that this is a far from expert review. I could have waited until I was more knowledgeable to post it, but I know a few members are interested in this light so I thought better to do it now and hope it helps. I'll watch this thread as closely as time permits over the next few days so if you want to ask me anything I'll do my best, just don't be offended if I don't get back to you straightaway as I'm mega busy at the moment and can't stay glued to the PC. Good night for now.
