Since NCR18650A is the one I'm most interested in that's just going to have to be good enough. ;)
Thanks for all your hard work.
Sanyo 2600
Panasonic CGR18650CH 2250mah from international outdoors
Thanks for doing this and looking forward to the test results.
Im intrested in the NCR18650A PROTECTED batteries Hank at a discharge of 3 and 5 amps
I have this on order and expect to add a 7A and 10A discharge rates to the test for this cell.
I have read your test of it and am very curious if it is a general problem with his cells or if you just was unlucky.
Im pritty unlucky, but i guess your test will be effected if the PCB,s only have one mosfet in them.
The number of mosfet's does not have to be a significant factor, you can get mosfet's in many qualities and one good mosfet can be better than two cheaper mosfet's.
So true but what quality do you think your going to get for $1.99 usd installed with wrapper, label and one mosfet, including some ones time to weld it and put it all together ?
Like i said im pritty unlucky but it would be nice if more people could test these protected ones with discharges higher then 1 amp.
Mine took 16 days to get here to Australia, so yours should be there any day now to test and im sure they will be fine.
There are definitely fet's and fet's!
Must have thousands of the critters in various ESC 's and they get a good hammering in electric powered aircraft up to 12s li-po and if they are naff they zap real quick and melt plastic nicely.
As for me I would like to see something on these, might score some to checkout today after a BLF search.
M.
I saw that link yesterday and has been thinking about including that cell.
Next "problem" is prioritize the tests, in one to two weeks I expect to have a large pile of LiIon cells. At the current time I only have a few (TrustFire and UltraFires) and Callies that is testing at the moment (The intl-outdoor will be tested when I receive it).
I expect to be running the test equipment continuous for the next few months, producing one to two test/reviews each week.
Thanks for the good and hard work! One thing to note is that in flashlights, unless you are in sub-zero conditions and at least a 5kph breeze, is that the cells would be somewhat warm. ie from both the discharge as well as heat generated by the light being switched on continuously. It is winter now, and if your house is at 10 deg C, it might not be a good indicator. Lots of people live near the equator too.
But i don't think Denmark is that cold, so if the house is heated i guess it's ok. Maybe place the cell on the charger (warm), probe it with a IR thermometer first?
It's 28.9 deg C in my house right now, and that is considered quite cooling. I switch on the air-conditioning usually after i bathe....and keep it at 26 deg C (24 deg C at first to cool my body). At nearly 30 cents per kWh it is not cheap!
The test will be at 25 to 28 deg. C, that is my usual indoor temperature.
Outdoor we are just about down to freezing temperatures during the night, later in the winter it might go down to -10 deg. C or lower, but probably only for a short time.
The Li-ions cells will no perform that good at 0 Celsius or 10 Celsius. They will improve in capacity if they are discharged at 40 Celsius or even higher. That is all manufactures say in their official graphs.
HKJ, have you though of test at -10C, 0C, 25C and 40-50C ambient temperature to see how the official ratings do ?
Not really, I do not have any equipment to easy do that. I could probably do a test in the fridge and the freezer or even the oven at low setting. This could be fun trying on a single cell, but it is not something I will be doing on all cells!
Anyway, I do not have time for it just now, most of my good equipment will be tied up on this big LiIon test for some time, but remind my again when the LiIon test is about finished.
You guys have all the fun with all that cold weather.
One guy from Finland said he wants to relocated to Singapore though....he loves warm weather. I told him it's fxxxing humid here, but he said that beats below -10 deg for a good part of the year.
My wife loves snow. Think we'll be visiting Seoul sometimes in Feb (only time when we'll be free). Second time we'll be there. Japan is quite "discounted" now in addition to Thailand, but general spending is still expensive in Japan, no make that !@#$!%$ expensive.
OK, I understand.
Well you never know you might end up find the best performer in -10 ambient. Maybe we'll have cold best performer and a hot best performer. Quite unlikely, however it would be something very interesting.
I actually wonder if we really have the fun, since li-ion perform very bad on low temperatures. But then again the low temperatures are good for the LED.
Playing around with the data from a few tests I tried doing these bar graphs, that shows the capacity down to a higher voltage than I tested to (2.8 volt).
I could be useful sometimes, but what voltages are most interesting?
wow Thanks HKJ
Wow. That is a very interesting comparison. Thank you.
