I got a brown box with a Nitecore yellow label on it, picturing the TM03 with a pocket clip. Inside was a fitted foam insert that held the light. Nothing else. No extra o-ring, no papers zip. I removed the foam insert and nothing under it in the box. Seems weird, never seen a Nitecore come without all the accessory stuff like what you got.
Sorry, I did get the holster. The battery was inside the light.
Slightly smaller lights like the MH20GT and PC12GT have come in a yellow box with a hanging top for putting on a display rack (as did the Caveman and EC4), with all the paperwork and stuff. I got the TM36Lite in a big brown box labeled similarly, it didn’t come with a pocket clip either.
I DO EDC it. Not over my modded lights but in addition to.
I like the style, the UI, the beam profile. As far as that goes though, to be totally honest, I’m pretty sure the Manker Godmes does about the same thing in a smaller package. Or an X5 for that matter, in a tail clicky instead of side e-switch. In the few days that I’ve had it though, it’s been the longer range light in my pocket as compared to my Ti Quad 219C and Texas Poker.
The one I got has a fairly blue-white XP-L HI in it though and that’s the one thing I’m not really liking. Looked at it today and thought about putting a 3A in it but haven’t so far, trying to keep in mind that I have few if any ANSI rated lights to compare to and this one measures out in my lightbox almost exactly according the specs. (in Turbo, not so much in the middle modes)
My TM03 now has a QO MT-G2. Mostly the swap went well, getting the o-ring back in around the reflector and under the lens has proven impossible. Seems that it swelled after being removed and it just isn’t going back in the way it was.
Well, I really like the MT-G2 and it’s creamy color output. I really don’t like blue-white light, which the XHP-70 was in this particular light. So I guess it just boils down to getting what I want, whether Nitecore offers it up this way or not. It’s still using a single cell, still the proprietary cell, and still making some 2500 lumens. Since we always lose some lumens dropping down to a warm white compared to a blue-white tint, it’s pretty much a wash in the output department. Beam profile might actually be a bit tighter, certainly better looking and easier on the eyes.
Other than that, it gave me something to do other than watching TV.
The MT-G2 has a much more consistent tint through out the angle of emittance from the LED, ( much similar to the Nichia119/219 does) while the XHP70 has some severe tint-shift to yellow then green as the angle gets steeper, much like an XM-L does. (shallow reflectors tend to reflect this yellow/green tints from the sides of the LED more than deep reflectors do, Like the syndrome the original first Olight S20 had, and the new Klarus G20 does.
The TM03 has a deep reflector with 2 zones of angle, down close to the emitter the angle of approach is steeper, then it flares out more above that. This can be seen in the double effect in these shots. In this instance, as in the Solarforce M8, which uses a hybrid reflector where the lowest section is orange peel and the upper section is smooth, the big MT-G2 seems to like the approach yielding a nice beam.
I think this is MT-G2 number 12 for me. The least likely is my Solarforce Skyline I, with an incredibly deep reflector. Something about the fat boy emitter is just really appealing, the look of it, the creamy rich color of it’s light, and the rugged nature it seems to have in spades.
Not sure Franz, they’re probably pretty close to the same at this power level. Both are capable of making a lot of heat, to be sure. I know the big MT-G2 really cranks it out when pushed up over 7A and at 12-16A it’s pretty crazy.
