I just made my order... :FACEPALM:
I would be expecting the drivers to be bad like when i programmed my Baofeng radios so many driver issues
Is the usb to serial device showing up in your devices?
My first install attempt It didn’t work and I went into my devices and the usb to serial wasn’t there.
Used the driver app to “uninstall completely” then tried again and it worked. Had to restart windows for the software to pick it up and connect.
Also it looks like the last driver update was 2 months ago
Here’s what mine does.
Tried everything with the newest driver and having the meter on when plugging in etc.
That’s exactly what mine did.
Use the driver again. Do the complete uninstall. Restart comp. Install driver again. Then restart comp again before you try.
Very important to restart comp before and aftrr
Where did you d/l the latest drivers from
No amount of uninstalling or restarting helps mine.
Nice find! I will follow this thread and order one if it will have positive feedback from you guys.
Has anyone tried using the Python script linked in the CPF thread?
-Michael
Ok. Update.
The driver software is definitely a prob. I’ve had to reinstall it a few times.
What seems to work is leaving the meter plugged into usb but power off when you install. It looks like the auto play when you connect it has the ability to corrupt the driver.
Either way. Its a huge pain! Fyi.
I ran a test run on the lumintop tool and exported to xls. The light curve was the same shape as my previous method and other reviews so the meter is somewhat accurate.
Problem is it only exports lux data, and since the sampling rate is 2x per second you can’t make a chart with a push of a button.
Also seems like the first few recorded lux values are always wrong.
So the driver is definitely buggy, and your data set is going to be in 1/2 seconds.
Which can be a huge pain if your doing a 7 hour run. Which can mean like 40,000 data points.
Also finding runtime means doing some light math
I got one of these too… and there’s two problems:
- After recording 7200 values (about an hour) the supplied pc software just deletes all recorded data and starts over!
I didn’t find any options to change this so I guess it’s a bug in the software. So I just use the device memory.
- Quite a lot of noise in the signal. Big noise over 20k lux, and smaller noise over 2000 lux.
Here is graph I recorded from my Olight S20, just moving it further and closer to my diy integrating sphere.
Here’s a closeup of the moment when the light intensity goes below 2000 lux (=41 lumens in my sphere)
The above kind of transition would be hard to average out. If somebody knows how to get rid of this “noise”, I’m listening.
Here’s a finalized runtime graph, from google spreadsheet. you can see the bigger noise component, which disappears below 20 000 lux.
How long does your device memory last? Mine shows full after 15 minutes. It only stores 1900 readings in the device for me
I also have alot of noise in my readings.
Pretty close to giving up on this. Its so buggy and the driver keeps corrupting and having to reinstall.
Has one one tried to make this work with different drivers? Or a different program what about a name brand lux meter that uses the same internals that may work?
You can only set the interval in the supplied Luxlab software. In setup, there’s “auto store period x seconds” where you input the desired interval. Then click upload.
This thing doesn’t use a hardware level driver because it has a serial interface. It uses a prolific USB to serial chip which needs a driver. There are many different chips so perhaps you could try a different one. I came across this page, perhaps there’s something that may be of any use.
http://www.serialgear.com/usb-serial-adapter-drivers-windows-mac-linux.cfm
Any trick to getting it to upload. I click and nothing happens. The interval doesn’t change.
So I went on the link Nisei posted. I tried the 2009 “get all drivers link” and it fixed my driver problem. It connects flawlessly now.
I got mine without any software.
I looked for it on the internet without any luck. I contacted benetech and I’m waiting their answer.
Any chance any of you could share his copy? Thanks.
Sent you a PM.
Driver does't work with my Windows 8. Luckily, I have an old notebook with Windows 7 loaded. Installation was pretty straightforward. Somehow I am able to measure beyond 1900 mark. Will monitor if it will auto reset at one hour mark like what tek-0 has mentioned.
Up till this point, I would not recommend GM1020 to the rest yet.
