Nice review, thanks.
The Lux @1m with the original protected Klarus 18650 was about 40K, with the LG HG2 it was nearly 50k. So the LG HG2 give like 25% more lux, of course it will drop fast in a real life situation.
This was actually not correct, it seems i have a problem with my tailcap. I tested it several times and i always measured only 27K lux with the original Klarus battery but 40K Lux with the LG HG2. I couldnt explain it until i removed the tactical ring from the light, then i measured 40K lux with the Klarus 3600mah cell as well with my new luxmeter. I never had such a problem before, i cleaned the contacts and the tightened the internal tailcap ring as well but still the same problem. I guess something is not right with my tailcap.
Thanks for the review. I am on the fence on this one. PWM is a big negative. SB reviewed the XT11S and didn’t notice any PWM. There ad claims constant current.
Question.
If light is on any mode other than turbo , what happens if you slight press main rear switch???
Can you have momentary TURBO while in low, medium or high???
Hope my question is clear.
I never had the XT11S, i test it with the slowmotion funcrion of the smartphone camera.
Ok, thats probably not the answer you want to hear but it the light will go out when doing so. when you are on lets say low mode and slighty press the tailcap clicky you will get momentary turbo but the light will go out as soon as you release the tailcap clicky.
Have you heard of anyone else having pwm on low modes?
Maybe you got a bad one.
Yes, german reviewers in the german flashlight forum discovered it as well. I guess you already heard of the new version of this light, maybe this is without PWM if you are sensitive for PWM.
Well I ordered one. Hope I get an improved version.
No, you have to order the new version, you wont get the new version if you ordered the old one.
How do I tell them apart ??
The new one comes with XHP35 HD instead of HI like the first version.
Well BG’s add is saying both. It’s on the way.
the new version should also come with the 3100mah IMR cell instead of the protected 3600mah. Like i mentioned earlier i tested the old version with an LG HG2 cell and it was brighter as well.
I’m kinda lost. Is the new version better or worse than this one, and what exactly are the differences?
Some prefer the old one and some the new one. The light was marketed as a 2000 lumen flashlight and it could not reach that claim, i guess thats why they offer the new version now which should be a bit brighter but has less throw since it is the “Hi” Version + it comes with the IMR cell. All those steps should make it brighter, i dont know if it can reach 2000 in the end. Im sure many ppl will test that for sure. I would prefer maybe the new version because i dont care that much about throw
3 switches…
3 switches…
yeah but i like the additional paddle switch. You obviously dont like 3 switches
I am thinking 3 switches will work great for my uses. Underhand while walking, overhand while spotting something afar. Will have to wait and see.
Hello everyone.
I’m new to the forum and torches in general.
On Monday I ordered an XT11GT from banggood thinking it was the new HD version. I have since noticed that their webpage states both HD and HI on it which is confusing. My confirmation email says that the old HI version has been posted (I have sent banggood an email asking for confirmation on which version it is).
The German forum says that there’s an issue with PWM flickering on the old HI version and there might be a problem with overheating too. If I receive the HI version would I be better off sending it back and getting a new HD version instead?
Thanks in advance,
Steve
Steve, I have one on the way also. I also asked them if it was the version with PWM.
They said it didn’t have PWM.
I have also messaged Going Gear (they have run out of the HI and only have the HD available now).
They said that both versions will be just as reliable but the HI is brighter and will last longer.
