Thanks for your support.
I haven’t bought yet, but I’m looking at that U’King also. When I first saw the picture, I thought it might be a 16340 or 18350 diving light. How cool would that be? Still, it looks fairly compact for a 26650 light with magnetic slide dimmer! Diving style lights are usually made with thick/strong host materials. That’s what really makes it interesting to me.
U`King ZQ-CJT09 LED 800LM 2-Mode Focusing Stretchable Flashlight with Luminous Display
Code: King9 after discount $7.99.
Ends ON:2016.11.2
FEATURES
New and in a good condition
Compact and convenient to carry
The wear-resistant aluminum case could resist any potential damage
With 2 modes for meeting your different needs
It supports IPX-4 daily water resistance, not for diving
Support focusing and retractable design
Unique luminous display function
U`King ZQ-X920B XHP-50 6000LM Stepless Dimming Waterproof Portable Diving Flashlight
Code: King92 after discount $43.99.
Ends ON:2016.11.2
FEATURES
A commonly used lighting tool in various fields
Mini size, lightweight for convenience
It supports IPX-9 daily water resistance
Support stepless dimming mode
With crush function, ideal for self-defense or emergency
ok . i got it
Code: King96 after discount $6.99
Ends ON:2016.11.9
FEATURES
Compact, with built-in pen clip for easy carry
Support focusing function
With 5 modes for meeting your different needs
U`King ZQ-X918 XM-L2 3600LM 5 Modes Waterproof Portable Flashlight
Code: King91 after discount $16.99
Ends ON:2016.11.12
FEATURES
Klarus Mi7 Mini-Might XP-L HI V3 700LM EDC Mini LED Flashlight
Code: KlarusMI7 after discount $36.99
FEATURES
Come in finger size, stainless steel side switch for one-handed control
XP-L HI V3 LED, max output 700lm, max runtime 67h
5 modes: High - Low - Moonlight - Strobe - SOS
Power indicator displays remaining power for easy monitoring
Lock-out mode specially designed to prevent accidental activation of the flashlight
IPX-8 waterproof standard (2 meters submersible rating) to cope with bad weather
Efficiency circuit with broad voltage range to accommodate both AA and 14500 batteries
Over-discharge protection automatically lowers output levels to protect rechargeable batteries
Constant current driver with no PWM flash, suitable for photography illumination
Aero grade aluminum alloy body with CNC precision machining, superior heat dissipation
Military grade hard anodizing, AR coated mineral lens
ShineFire C8-R2 248lm 5-Mode Dimmable LED Camping Flashlight Torch
Code: SFC8 after discount $7.59
Ends ON:2016.11.12
FEATURES
Tough yet lightweight, ideal for camping, hunting, cycling, climbing and many more
Solid high-power LED gives off ultra bright white light up to 248 lumens
36mm Highly reflective light cup concentrates the light to reach a longer distance
Rugged aluminum alloy casing resists rust and corrosion
Five lighting modes, including strong, low, glimmer, strobe and SOS flash
Easy-to-use tail switch
High quality, up to 100000 hours of long service life
That U`King ZQ-X918 is kinda nice. I like the “silver” color. I would take off the cigar ring, though, if I got one.
MANKER E14 NICHA 219B 4-LED 1400lm 5000K Neutral White Flashlight with Clip Black
Coupon code: E14 Price:$42.99 Expiration time: 26th, Nov.
Thanks a lot for @Budda reviews: Review: Manker E14 - 4 x Nichia version.
TS-H3 XPE Waterproof Focusing 3 Modes High Brightness LED Flashlight
Code: TSH3 after discount $3.99
Ends ON:2016.11.16
FEATURES
High-class aluminum alloy, fine workmanship, good durability and stylish surface
3-mode design allows you to randomly adjustment the brightness
Support waterproof and focusing performance
Handy size, lightweight for convenient carry
It is powered by AA or 14500 lithium battery for continuous working
UltraFire 1000lm 3 Mode IPX6 Waterproof LED Diving Flashlight
Code: UFX6 after discount $14.99
Ends ON:2016.11.16
FEATURES
Light weight, low power consumption, compact and easy to carry
It is so portable and lightweight that you can carry it anywhere
Made of high quality aluminum, it is sturdy enough
Ultra-clear glass lens makes light brighter
Non-thermal radiation, safe and stable, reliable
Excellent waterproof performance
U`King ZQ-X918 is a good flashlight, you can have one.
Ultrafire Newfashioned 8 Modes XM-L2 U2 Cool White Light Waterproof LED Aluminum Flashlight
Ends ON:2016.11.16
FEATURES
New and high quality
Premium aluminum alloy, durable and reliable to use
It sends out soft and bright light, eco-friendly and energy-saving
With 8 modes for free adjustment
Widely applied in our daily life for lighting purpose
Portable and handy, convenient to use
Support daily water resistance
http://www.tmart.com/promotion/Black-Friday-3.html
http://www.tmart.com/promotion/Black-Friday-Sale-2-04.html#top_con
