Mass will only matter that much to transfer if you don't hold it in your hand. Otherwise your bloodstream (liquid cooling :)) will keep the exterior within a few degrees.
I wonder how is the tint on Tank007 cree lights? I find that some brands tend towards warm (like Skyray's mode lights ~6000K) and some run cool (Hugsby ~8000K).
Thats an interesting thought, and we're definitely on the same page with your concerns. The 703 is heat sinked properly to the head and body. I've had mine apart to have a look. It will get hot but takes much longer than the A3. The aluminum is machined and much thicker than the A3. In fact, the A3 reminds me of a cheap thin extruded aluminum soda can the way its constructed and I was quite disappointed when I felt how light and cheaply built it is. I get about 55 min run time from the 703 on eneloops, which is actually a completely moot point for me since I don't use alkalines. Again, and hands down... I'll take my 703 over the A3, regardless of which one costs more.
I cant tell you how many times I had my 703 on my keychain and was amazed for its sheer ability to throw far, particularly for its size. IMO, the A3 fails miserably in that department. On one unplanned camping trip into the wilderness, I had only the 703. After darkness fell, we could hear several large animals running around the aircraft, which was at least 150 yards away. One ran into the tail section which made a large thud. Having no way to get to the aircraft quickly, I screamed at the top of my lungs to scare off anything in the vicinity. To my surprise, the 703 cast enough light to illuminate the plane and several deer that were competing for food by the plane. Now I pack a few 18650 throwers in my glove box for those unexpected trips.
That's interesting. That's a draw of only like 0.7A?? A3 on high is supposedly about 0.8A. Xp-e's are also more efficient especially in something of that size because of their smaller primary lens and therefore larger reflector coverage.
I just measured 2.08A on a slightly discharged AAA eneloop (tones 2nd gen) after 5 sec turn-on. I'm sure it will decline as the battery burns down. The tint is probably in the upper 6k range. Its whiter and a bit bluer than the cold white tint of the A3. The 703 tint turns a dingy green color when the battery is about 75% used up but has a nice tint otherwise. The A3 is definitely a better indoor whitewall hunters floodier beam, and mine gets used a lot indoors. The 703 has a center hotspot that increases with distance. There is a prevalent ring around the hotspot that shows up on a whitewall but not noticeable outdoors. The ceiling bounce test is almost indiscernible between the two. I have a dark hardwood floor with wooden furniture so not as much light will reflect as apposed to the usual home in the same test. When the beam of the 703 is transposed over the A3 beam, the A3 beam gets completely blotted out by the 703, accept for about 20% of the larger A3 corona that remains untouched.
703 = best outdoors and for throw.
A3 = best indoors or where multimode output is required with flood beam
So runtime is more akin to the black cats (AAA will be much less than 750mah if run at 2A, so maybe it dims a lot), which isn't ideal with a 1 mode light. It'd be nice if they could just add modes.
Its far brighter than the A3 till 75% of the battery is consumed. I read somewhere that the 703 is brighter and built far better than the blackcat so I didn't buy one. For my purposes for a keychain light, the multimode on the A3 has proven to be far more of a hassle than a benefit. The darn thing has to be twisted three times to get to high mode. If done to quickly, it stays in the same mode no matter how many times I twist it. That's a complete hassle when outdoors and trying to illuminate anything past 10 feet away, especially when I need the light RIGHT NOW and trying to operate it with one hand. IMO, the ideal AAA light would have programmable modes with memory.... candle, low, med, high, turbo. I built a Hugsby P31 with a custom driver I use for my EDC with those modes and wish I had one like it for my keychain. IMO, the 703 is the next best thing. Just as all pilots are trained, start the light with your finger/hand over the lens and gradually uncover it just enough to adequately illuminate the subject, thus saving your night vision. Probably common sense for most people but still part of mandatory instruction.
On a night flight last week, I dimmed the cockpit illumination and kept the P31 on in candle mode and placed it in my lap for the duration of the flight. Every few minutes, Id pick it up for a quick panel scan. The difference in my night vision sensitivity was astounding after 30 minutes, and I was able to easily land without the landing lights for the first time at my home field.
Tank TK 703 = contact problems, bad switch, protected 10440 does not fit, bad keychain attachment, only 1 mode (10440 suffers on that high amp draw), and more cons
I prefer to pay 16 euro for the itp than 10 euro for the tank. For only 6 euro more you get itp quality, 3 modes, less weight, less size, etc....
True, only unprotected 10440's fit, but the drop-off in light output by the end of a discharge cycle (around 3.5V) is pronounced with a rapidly dimming led signaling its user to switch out a battery. I've ran my 703 through several sustained on-time cycles using 10440's and have never had any problems with the switch or otherwise. Of course I take apart all of my lights and clean, lube and adjust switch contact points before pumping large amounts of current through them. If the tail is getting hot, there is an obvious problem with the switch contacts where they meet the tailcap. Only a few 703 switch failures were reported otherwise. Not bad considering these things are sold by the thousands.
When my hand is used for cooling the light while using 10440's:
703 = hot but tolerable and can leave on through the entire discharge cycle. More surface area with knurling and larger, longer, heavier body.
A3 = burn the living crap out of my hand within 1.5 minutes. If you have really big balls Fran, you might be able to hold it for 2 minutes if your light doesn't go up in smoke first.
Some EOS have threading issues at the moment where the threads seat the driver to the body tube, thus creating intermittent contact issues, unintended mode switching and difficulty in turning as the light heats up. Mine did that and I sent it back. Its also been a know issue with ITP, which they still have not resolved to this date.
ITP does make a fine light and the EOS is great for a multimode long lasting flood beam. I have four ITP lights and two of their much larger Olight cousins (AAA through 18650). Although well finished, I don't consider any of them worth the extremely discounted prices I paid for them. Never will any of them accompany me into wilderness areas 50+ miles from civilization where the only engine driven machines allowed are aircraft. These lights are elegant but not robust enough to take any real punishment. Of the 6 lights I mentioned, 2 have been returned - one of them burning up its own driver... also a known issue for that particular model and continues to be manufactured in the same sealed system that does little to evacuate heat. Even my m20 warrior had contact mode switching problems which I resolved by polishing the contact surfaces with a dremel and relubing... another known unaddressed issue. Thanks again Olight!
So to date, these lights have proven to be far less reliable than any cheapie lights I have ever purchased or read about (and I have many of them). IMHO - Reliability not withstanding and while functioning properly, they simply aren't tough enough lights for the real outdoors enthusiast nor do they warrant the prices they command.
1.8A out of a 10440 is seriously asking for trouble. At best the cell will have a life of weeks rather than years. At worst, I don't want it in my hands. If you don't care much about cell life: which I don't - then I'd still worry about having hands after a few weeks of that sort of treatment. Anything pulling more than 400mA from a 10440 is asking for trouble. You may never get it, just kill the cells, but there are other possibilities. Choices, consequences. My job is to say that every day of my working life.
I'm a smoker. 50% of all smokers will die from their addiction. In a bad way....
Sorry, I should have added that those measurements were on NiMH. 1.8A @ 4V from a 10440... that would make for quite a tiny hand grenade wouldn't it? Stop smoking Don! All the photons from the light energy will probably give you melanoma first anyway.
If you like the TANK007 TK-703, but are missing the medium and the low modes and you aren't too annoyed by 2 additional strobe modes, you could also consider the Brinyte PD03A (xr-e Q5) 5-mode. Mine is nice and has no PWM flickering. (unlike my Maratac)
Like every other smoker out there, I want to be an ex-smoker. The last time I tried to stop I gained 20kg, 50lbs in weight. Last year. Once I've lost that weight I'll try again.
But let me tell you about a heroin addict patient of mine who spent $15,000 last month on heroin.
Just don't ask how she got that much, I really don't want to know.....
Or to ask.
Melanoma round here would require sunlight. Seriously that is not a big issue round here.
My father did have a melanoma removed from his right foot a couple of years ago. I doubt that foot has seen as much sunlight in all his 78 years as mine did in 1984. Just look at how far north Aberdeen in Scotland (Not the 30-odd imitators) is. Serious sunlight just doesn't happen around here.
But if you kill an NiMH, no big deal. While I have provoked NiMH cells into doing bad things, none of them have involved flames. Or explosions.
Thanks for the links. I probably wont be buying any more AAA lights unless something new and revolutionary comes out some time in the future. What I'm hoping for are LED's with much higher flux densities and consumer level composite nanofibers for applications in lithium batteries. Still, its a great time for the flashaholic to be alive, and I really do enjoy all my darn flashlights... god help me.
Here's an interesting CPF link the Ray S20 and other high powered AAA lights, albeit on the pricey side.
Yeah, this S20 looks nice, it's in the same ballpark as the Preon 1, the Revo and others. The problem is, I'm still more limited by my batteries than by the selection of flashlights or emitters. If you look on the lightbox number in your link... the Illuminati pumps out a whooping 106 at max in the lightbox on 10440. But you can't have it all - turbo brightness , long runtime, cool running AAA - not gonna happen any time soon. Unless you invent a fusion reactor based superconducting AAA flashlight. The price is also an issue for me ... AAA are prone for losing them easily... I live in constant fear of losing my beloved Maratac AAA SS BB which I paid ~34 $ for... hence the lanyard thread. ;-)
Keep an eye on the self-discharge it may well have increased and doubtless the capacity has been reduced.
A lot of protected cells don't cut off on low voltage anyway.
My guess is that the voltage dropped enough for the light to cut out (Lithium ion cells voltage can sag like crazy under load) and it decided not to restart when the voltage recovered once the load was removed.
Keep a very close eye on it when charging though - it is when charging that cells are most likely to blow.
If it can hold above 4V for a couple of days after charging it'll probably be OK.
