What did you mod today?
Using original (stock) reflector ?
Yes, stock reflector but i might be wrong about the current because it is direct driven, no driver at all, so it might be higher. At the time of the test i had three 25R’’s in it, ive seen that same led pull just over 5A from a single cell, so with 3 in parallel there might be a bit more juice delivered to the led.
My TM16 is making 109.75Kcd, essentially stock… I didn’t change anything on the driver, still has the NW (on the warm side of NW) emitters, but I used 18ga Turnigy leads throughout, in place of the 20ga they used.
So I’d say you’re in the ballpark.
I’m using fresh charged LG HE-2 Button Tops.
Direct Drive for Turbo? Where does that info come from? I see an R010 sense resistor on the driver… mine tests out at a bit over 4100 lumens.
As djozz explained me :
Yeah, tested it, three 25R’s @ 4.19V = 5.7A at the tail, so there it is, it is more than 5A.
Probably misremembered DD.
Max did a really nice write up on the TM16.
With the lumens Nitecore quotes (4000), Turbo is probably like 2.8amps per emitter. It still could be susceptible to a tenth of a volt or two.
My only remaining Courui D01 also uses 25R’s, it’s making 545Kcd with an XP-L HI for 1476.48M throw.
Not liking myself for selling the SBT-70 D01.
(gotta see if I can tweak it for that remaining 436 feet to make a mile. :smiley: LG HE-4’s will probably do it. :wink: )
Edit: Best is actually from Efest 35A’s in this light, at 557.5Kcd for 1493.32M. Still some 381 feet shy of that elusive mile. Oh well.
Today I swapped the emitter of my Olight S-mini :
Lol…you made someone a very happy camper though. You were able to spread your joy elsewhere. My edc has been the X5 since I received it and it probably will be for a long time.
545kcd using xp-l hi ? Sweet .
Also , anyone using the 86mm KD reflector in his D01 ?
How did you focus your D01 for that throw?
Yeah, that little quad is a pretty dang sweet light, for sure. Dang sure won’t be picking one up at Wally’s World anytime soon… :laughing:
Nothing yet but it is still early...
I cheated unknown. The “Big Head” Courui is now the Mega Fat Head Courui. :smiley:
153mm Seanna optic.
Ohh i remember now :smiling_imp:
Shame Shame Shame. :wink: :stuck_out_tongue:
I need to tweak mine. It was such a pain for me to mod it when I finally got it all together and properly centered I just left it. Low 200kcd’s iirc. Really disappointing for a FET XPL-HI in a Courui D01.
CQG Carbon Fibre
I recharged the batteries completely in these 5 and measured again. The only other change was that I removed a rather tall centering ring from the Courui, but it didn’t make much difference. It was one of my earliest mods, and I have a feeling I just need to completely rebuild and update it. Any tips on where best focus is? Right now the reflector is directly on the mcpcb. Not sure if I need to raise it up more or sand some off the reflector.
Marked improvement in the L2 with a charged cell.
Here are the numbers:
  • Nitecore TM16 - 105kcd > 111kcd
  • Solarstorm SP03 - 236kcd > 255kcd
  • Courui D01 - 231kcd > 239kcd
  • Brinyte B158 - 230kcd > 243kcd
  • Convoy L2 - 130kcd > 194kcd
Sweet mod CRX !
I sit a wrap or did you fit the CQG into a carbon fibre tube ?
