I put mine on the lowest setting it would go, I think 0.04A or so as I recall. Touched two aligator leads to an xml-2 star. I don't remember now but the Vf was impressively low, maybe less than 2V even, but the led was clearly lit. But it would pulse about once every second, steady, and a then a quick brighter blip. I don't know maybe it's ready my ekg or something, lol. I wouldn't expect a high dollar bench supply to do that, but that's not really a criticism. It's doing great as a hobby supply and this was pushing its limit clearly.
At the extreme ends of the working range it is not the most precice device but then you don’t use your DMM set to 10A range when measuring micro-amps. So using a 15A power supply is sort of like that.
My smaller 5A unit is a lot more stable at lower voltages/currents when you get down to the milli/microamp area. It says it should be in the data sheet as well.
I have the DPS3003 and it’s great for small arduino stuff and LEDs, the display is accurate but I’ve never seen anyone scope the output and comprehensively test the thermals and output capabilities.
A decent buck/boost will be very popular
My only niggle is that the encoder knob is quite small, but it’s a very small unit so what can you expect.
My niggle on the 5015 isn't the size but that's it one knob with a funny push-to-select-digit interface and an enable timeout, instead of classic 4 knobs V/A course/fine. But yeah... that's all money and space. The auto-lockout can be considered a feature too.
To be clear, any power supply with an output a couple volts higher than what you want out of the 5015 will work. In other words, if you don’t need more than (say) 15 volts, you could use a 24 volt supply. This is cool because old computer power supplies are often scroungable for a little bit of effort. So you can save up for that nice 48 Volt supply you have your eyes on.
Correct, it needs a few volts of overhead for the buck to operate.
Although most computer power supplies around here are 12V, servers have 24 and 48V supplies though. I am using the DELL server power supply posted either earlier in this thread or the other thread on the dps5015.
For the price the DPS series can not be beat, naturally for more money there are better options.
I will say that while I like the 5015 unless you need the 50V and 15A capability it does have more ripple voltage then my older 3012 and my 5A version has basically zero ripple (around 10mv IIRC). For most things 30v and 12A is more then enough, heck the 30V 5A version is even more compact and enough for a lot of things, although not enough to really test LED’s now days.
Here is the Design for the Acrylic case I made in case anyone wants to make one. It is cut out with a laser cutter from standard hardware store .08” acrylic sheet (“plexiglass”). Thicker acrylic would be stronger but costs a lot more and is much harder to find.
Proper acrylic glue will be stronger and look better but hot glue or super glue works just fine as well.
Which power supply is best to use with DSP5015?
AC 110V/220V TO DC48V 8.3A 400W Regulated Transformer Power Supply For LED Strip or
AC 110V/220V TO DC 48V 400W 8.3A Single Output Regulated Switching Power Supply
Got a link to them? They sounds like the same thing.
Although either should work, all that matters is that you get a DC voltage out and a 48V output is a great number, you rarely need those last few volts.
Here is some explanation, but I really don´t know which one is the best for the DSP5015. More heat but cleaner current with transformer, less efficient.
The two you link to is both switch mode supplies.
Old style transformer based supplied will usual last considerable longer than cheap smps, they have less efficiency and weights a lot.
I used the MeanWell (I got the 48V, maybe ~7A iirc) that the supplier of the DPS5015 recommended, works perfectly and seems of very good quality for an aliexpress item.
