The XHP35 HI is a 12 V emitter, that will operate at around 2,5A.
Doesnt that mean 12*2,5= 36Watts in total, a part of which is being convcerted into light?
Lets be generous and suppose the Led has a 15% efficiency, that would leave 30,6 watts of generated heat.
I think besides the minor fin changes the existing renders by 5AR are the best bet, I don’t see many major changes happening externally until we have found a reflector and figured out if cell carriers will be used. Both of which have to wait until we find a manufacture.
Is it even worth adjusting the fins for the initial presentation to the company?
. Thanks for confirming my calculation!
So, this light will produce around 30 watts of heat, instgead of the aforementioned 40 watts.
Question: will it be able to absorb the heat produced at turbo without more cooling fins for more then say 10 - 15 minutes or will it get to hot to handle?
Maybe someone on the forum could do the maths?
I can’t…….
It will be strongly depending on ambient temerature as well, so if calculations at different temperatures could be done?
Yep, that is a fact about running the L6 in Turbo mode… no ‘heat issue’ at all till the batteries croak.
So, that being said; overheating should definitely not be an issue with this proposed light.
Why bet?
Frankly i still think it’s very Chinese looking and to me it’s a bit of a put off.
And that’s why i didn’t contribute anything here in the past days.
I’m quite happy with the 8x 18650 config, and i guess the battery carriers are pointless too when there will be no short tube version, so that makes things simpler too.
It’s the head basically.
I think it’s plump and not integral with the rest of the looks.
This is more or less what the design was inspired by actually. We didn’t want to copy it anymore since convoy is not making it and it would suck to flat out rip off the design.
Plus adding fins only adds weight to an already very heavy head.
wowowow, it is too much L6 for me as it is
the L6, blocks at the top and tail, completely different blocks on tube, the anti roll cut outs have nothing to do with any other part. I use it in the dark and am happy I only see the light it produces, the rest I do not really care about.
But that is me, “over smaak valt niet te twisten” or “no point in arguing over preferences” function on the other hand, yes, that is objective (or well should be ) thus seeing the current render, from top downwards, there is a straight line that goes on where the anti roll fins are. I think that this could and should be done smoother, so less deep fins there, maybe 3 less deep fins with little wider cut outs for anti roll.
We could eliminate the fins in the anti-roll cutouts as well since they are just cosmetic. The anti-roll couts could also be widened and spread out a bit further IMHO. So instead of 8 cutouts, reduce it to say 6.
That would allow the head to follow the contoures of the reflector close by, less material, less weight, and elegant looks right?
maybe just screwing in one of those nuts for thick lanyards in the tripod mount would prevent rolling too.
Same as this preliminary design…
Yet it looks… O well, the L6 is not exactly beautiful design either…
So let’s just stick with the first idea then?
I find that rather strange.
I don’t know about you,but when iḿ looking to buy a light, the exterior matters.
In fact, it’s the only thing you see when browsing, and a light either appeals to you or it doesn’t.
This decides the purchase, except when there’s no other choice and you really need it.
It doesn’t get any prettier with more thinner and deeper fins…
And considering the surface area of the GT, it’s not necessary either.
But hey, we have this decided (correct me if i’m wrong):
8 x 18650
XPH35
120mm reflector.
About anti roll:
I put lights on their heads on a table, not on the side.
None the less, it is better when it can not roll off the table for sure.
But i don’t like the sharp points resting on the table, it should be flatter i.m.o.
Also, every sharp edge will result in anodizing wear.
Look, i just say it would be good to have a couple of designs to choose from rather than stick with the first preliminary ideas.
I don’t know about you guys, but apart from being a portable light source, a flashlight is also a pretty piece of metal that can look really nice, which makes them desirable objects.
But apparently you and TA don’t care too much about the looks, so why not leave this more open for discussion for those who do care.
I mean, i fail to see the reason to stick with this design.
And i’m not gonna push my design (several pages back), but rather i would like to share thoughts about it here and have 5ar look at the options too.
One more thing:
Battery carriers.
WHY??
I can tell you why not though…
Alright, i’ll go see what i can do with my image editer, but things like fins and knurling are hardly possible…
If they end up doing direct drive (which I don’t think will work very well due to the voltage being too high) it will draw way more than 3A, I haven’t seen any tests done over 3A for the XHP35 so idk what happens.
If they use some current regulation and limit it to 3A, then it will be drawing slightly over 15V
So that’s at least 45W total, and 15% efficiency is a good estimate, so about 35-40W into heat considering 45W is an underestimate.
Also, the hotter the LED gets the lower the efficiency, so without proper cooling the LED could be running at 85C or even more which means less light and more heat.
If somehow they manage to do DD without the LED burning up then it will be using almost 17V and probably like 5+ amps, so a LOT more heat than just the little 3A test from above.
