It is not that we are unwilling to consider anything else as we don’t see the need for a change or that it could be improved in any major way (besides minor details).
As long as the base format and function remain unaffected I can go with whatever is most popular.
That said I STRONGLY desire an aggressive and powerful looking light to match the performance. Something bland and wimpy is not the image I want to see this light project.
Cost mostly, the heat is a massive hunk of metal already, by swapping to a smaller bar stock size for the smaller areas it saves cost.
It also opens the possibility of a quad version of this light later with only a head change needed. Which is part of why I want some nice fins around the shelf/button area to prepare for that.
No, “so be it” means that if I see something I like better… I’ll say so. Personally I’ll consider anything, but if I don’t like it I’ll not be changing my mind.
Thank you for your “apology”, but as far as I am concerned it is not necessary. You are just passionate about your opinion, nothing wrong with that. :+1:
I am up to look at anything. (not that I have any say so besides my personal opinion)
But like someone said, Texas_Ace I think it was; my vision also for this light is something aggressive, sturdy looking, and bold. What I have seen so far in the renderings ‘5ar’ has done fills that desire for me.
I have put together requested Save-The-Date refrigerator magnets, only to have the idea change, then tweaks, then a new idea, tweaks to that, spent days doing what should have been accomplished in hours. So I have a good idea what 5ar is facing… lol.
This kind of thing is why so many opinions “muddy” the water, easy enough for a lot of people to toss ideas out, but one guy somewhere is dedicating hours of free time to the project. Think of it not as free time, what if we were paying 5ar $100 an hour to draw this stuff up, how would we go about it then? Just a thought…
Thank you 5ar, you’re very incredibly awesome in the renderings and I for one greatly appreciate the effort.
Personally original design for me is just jaaaw dropping . Everything else proposed is just ruined the whole thing. 5ar you did a magnificent job and since you are from Croatia I would love to see led4power involved in this project with driver design….
Also I wouldn’t care much about heat disposal considering the size of that head. Just use a 40mm X 2,5mm copper mcpcb and 1cm thick shelf under and no problemo :+1:
Turbo should be time limited for 3-5 minutes,to be honest majority of time it would be used just for show off, but the HI mode should give 500Kcd with much safer Amperage and with no worries with heat…
The rendering by 5ar is absolutely amazing! I say we leave the cosmetic details for last and start to find who can produce the light to our spec.
About the fins, in a light this big it’s not the fins that will get rid of the heat but the mass itself, like the convoy L6 with thick and short fins and it does a good job managing the heat. Now imagine a much larger light, driven at less than half the power… how the fins look are not a concern here
Actually the power will only be a little lower by the time we are done with it and if a larger quad head is made later that will obviously be much larger. Might as well plan ahead but no need to get crazy.
I dont think 40mm is smart to use. More common sizes are much better and easier for mods.
Using a thermal sensor to step down to 90% if the body near the led reaches 60 or 65 degrees celsius? If light is colder than that then 2.8A to the led, if it is higher then 2.5A to the led. Job finished.
Narsil supports temperature control now, so it will have some form of temperature step down although ideally this light will not need it as it should be able to be used for real search and rescue missions as well.
Hey, did I read something about hourly wages, nice nice, does that mean i can look for a new car LOL
No of course 5ars work is much appreciated for sure.
But so is the work of DEL, Tom, Jerommel, and all that contribute
I really think that with the changes I propose in my previous post both design will come together and do justice to others who have given input.
Yep, knock yourself out ‘The Miller’. Considering what you are gonna make off this deal…… this will probably take care of all the “looking” you need to do.
I’d like to thank you all for a very-very good job with this GT, and I’m also very proud to be a part of this forum.
Humble is the right word!
Such a great bunch of dedicated people! NICE!!
And I also like the 5ar design, but still felling that thinner and higher fins to smooth out that ‘ledge’ area would be “right”, and just the sight of it would be Awsome!
…haveing som kind of real functionality in it to is just a big also? I think.
