$15 would be even better. But I don't won't to get to cheap.
I guess 15/16$ is not possible ...but the price need to be competitive for sure. If it'll be under 20$/pair, that will be definitely good price.
Well heck the Xtar 18700 2600MAH were only $13.50 a pair. $20 is getting up there. But that is my opinion. If your going to pay $20 for a set of these when for $7 more you can get 4 of the 2600MAH, I know which ones I would rather buy.
$20 would be a good price, just looked on HKE and the panasonics they are based on cost more, heck the trustfire 3000s cost $16.
I would go $20/pair if the quality of the wrapper and pcb are up to the Xtar standards and the capacity is close to the stated 3100Mah
+1 for Group buy
Don't forget we are talking about price shipped !!! Just to refresh - Group buy for pair of XTAR 2600 mAh was $13.50 shipped. If you extrapolate price based on capacity you get $16.10 so final $18 shipped for BLF members seems to be just fine.
Yes... I wouldnt mind paying $16 for a set... ;)
Maybe a $14 or $15/pair special introductory rate special?
For BudgetLightForum Members.
You can't work it out like that! It's not a linear relationship between cost and capacity! I'd happily give $27 for a couple of 5.2Ah 18650s ;)
$18.50/pr
$33.50/pr w/WP2 II (+$1.50 - car adapter)
$50/4-ea w/WP2 II and adapter
Shipped
i sent a email off saying ill test a couple
They seem to be from the same factory I got the eX-cell 3100s made in and also the Redilasts and CKs are made in, you get a choice of positive nipple design.
If ordered in a high enough quantity by xtar (to get a lower bulk rate and save on shipping) I can see the lowest reasonable price for a large-ish group buy being around $16.50-18 shipped for a pair. This is based on a low estimate of shipping to xtar HQ as I assume that isn't far from the factory, and also assuming no import taxes and relatively low outbound shipping charges (DX etc can do it cheap).
By the way, there are some very nice pictures of these new cells in the Xtar S1 thread in the LED flashlights section on CPF.
Would be intrested in a definate price, and wonder if the pcb,s would be better then the 2600 that you couldnt draw 5 amps from.
Pics from CPF (gopajti)
Thanks for doing that, I always have trouble with linking to pictures.
They look good, does any one know the maxium current draw the PBC,s can handle and the voltage cut off ?
If they are from the same OEM factory, the PCM they encouraged to use with these cells has a 2.5v cut-off and a max discharge of around 2C if I remember correctly, so about 6.2A.
No prob :) I'm really looking forward to these.
The minimum retail price from Xtar for the 18650-3100Mah is $13.42ea so the minimum allowed sale price for 4-3100Mah batteries & a WP2II charger set is $70.29, I've had the 3100 for almost 2 weeks but am waiting for my Xtar S1 to get here to test them against the Xtar 18700-2600Mah and see how they hold up in a 3000 Lumen Cannon. I'll post more when the batteries are available, right now they only have samples and you can't get any to put up for sale so for now you'll have to settle for the 2600Mah which is still a great battery and almost $7 cheaper till the Top Dogs are ready for sale.
