TY…it looks like that in order to use my eneloops, and get a long run time on moonlight mode { 3 days or more at about 1.5 lumens } im gonna have to raise my price target from $10 , to $20 . The xtar at $7.50 , seemed to good to be true for my needs/ price range.
I was talking about Lithium Primary AA cells, made to replace alkaline AA’s, not the higher voltage Lithium cells that we all normally think of when “Lithium” is mentioned.
Anyway, now that I’m aware of the 40 Eneloops that need to be used, there is no point in pushing another cell. lisa3070 needs a light that can do several days from a 2000mAH Eneloop.
If you want only moonlight, that may be your best bet. Find one of those cheapo multi-LED lights that take 3×AAA, load ’em up with eneloops (3.6V), and solder in a small dropping resistor to limit current to a few mA. (Breaking a PC trace in the right place and slapping on a chip-resistor should suffice.)
eneloops won’t have the same internal resistance as regular AAAs (much much less, in fact), so unless you want a bright light, cooking an LED at Vf=3.6V or so, you’ll need that resistor. (Value = trial’n’error depending on the Vf of the specific LED, and the current you want to push through it.)
So with 2000mAH in an eneloop, if you pick a resistor for 10mA total, you’d get 200H of runtime. It should be straight math to figure out runtime vs current depending on the true capacity of the cell. 25mA should get you your 80H target.
I live out in the country and we often have power go out for days. Wanted to find a inexpensive LED that ran on single AA or AAA eneloop for 3 days or more in moonlight mode / 3 lumens or less . Really, 1.5 lumens - 3 lumens would be perfect as long as it runs for 3 days or longer .
Lumens at .5 or less may not be bright enough. I am not interested in the light also having many multi modes or having a hi lumen output. I have other LED lights for those purposes.
I bought several of them , but have already wrapped them up to give for Xmas gifts , since they did not perform like I needed . I will keep 1 of them for myself though . For $7.50 , it is a good light…4 modes…pretty bright , and the moonlight mode is perfect as a night light, except for its low runtime . The tail clicky button is a bit firm, but thats no big deal.
I do think a better deal was the Cree ultrafire , that had the adjustable focus beam and ran on AA…I bought 1 of those a while ago off ebay for $2.89 .
I imagine the way LED technology is advancing, we will soon see a small budget light that will run on single AA/AAA eneloop at 1.5 to 3 lumens for
3 days or more, for under $10 . May even be some after xmas sales for the name brand ones, where the prices are marked down very low to get rid of year end stock and make way for new improved stock.
What im also hoping to eventually see, is a small LED light that runs on single AA/AAA , and has a built in solar panel , wrapped around the shell of the light, to keep the battery charged . You could keep it in the window sill and it would always be ready . They have flexible solar cells that could be circularly wrapped around the outer casing of the light . This would be a good seller for survivalist also . I see they have these keychain solar lights for sale, but they use a button cell/ watch batteries or a capacitor. It would be more appealing to me for them to use AA/AAA
The only AA-format lights I have, I run straight alkies. Whenever I ran down my Quark so that “turbo” would be as bright as, say, medium, I’d feed those cells to my bobofett light. Hell, even when my optical mouse would stop working, I’d feed those cells to bobofett (cheap 3buk 1×AA light from MicroCenter). I still have a half-dozen “dead” AAs that I’ve yet to burn through.
I had a few regular NiCd/NiMH cells that I was using for… something… but Hell if I can even find the cells, let alone the come-with chargers. A lot of old-timey stuff didn’t run too well on 1.2V vs 1.5V. Hell, even my scanners had a coupla dummy-cells for when using alkies vs Ni-* cells.
And other stuff that’d take AA alkies would fry with multivolt Ni cells.
(And that includes the WK50, because it’s only rated to 1.8V, iirr.)
The Foursevesn rep, made a comment that he does not recomeend using rechargeable batteries for this light,maybe because it would not get 60 hours runtime at the 3 lumen mode ?
If you look at, say, the Jetbeam Jet-I, you’ll see 2 different lumen ratings, one for Li, another for alkie. When you take multiple chemistries (and voltages) into account, you’ll get different performance.
They (being a reputable mfr) won’t just list the higher lumen output for Li cells, because then anyone using alkies will go bitching’n’moaning about not getting near that output when using alkies or Ni-* cells. And that’s when you’re feeding the light with up to 4.2V vs 1.2V!
Runtime when using moonlight mode, I can guarantee you, won’t be specced out for each’n’every chemistry when you’re using alkies, NiCd, NiMH, etc. Most people would care about light output at its maximum setting, not runtime using the lowest possible setting. That’s pretty much an afterthought.
But again (and again, and again, after multiple people suggested the saaaaaaame thing), TRY an AA alkie, and see how that fares.
Want a better example?
Buy a car that costs big bux, one that runs off E85 (“flex-fuel”, etc.). EtOH does not have the same energy density as straight gasoline, so your gas mileage will be lower using E85. Hell, my car’s mileage drops some with “oxygenated” fuel in winter.
Do you complain to Ford, GM, Toyota, etc., for not including specific fuel-mileage spex for straight gasoline, 10% EtOH in winter, E85, and so on?
You’ll never see those spex, because it’s presumed your mileage will drop with different fuels!
Yet you want to hold the maker of a 15buk flashlight to even higher standards? C’mon…
It sounds like you have your mind made up. David isn’t asking you to replace all your eneloops, just to buy a couple to run a test with.
There are dozens of reasons for different designs to have different run times. The best way to verify that ANY light and battery combination is going to do what you want is to test it in your environment.
Eneloops are great in some circumstances, but have trade offs that are sometimes worth it, and other times, not so much.
Ive already stated that for $7.50 , I think this is a good light. Im not asking for a refund from the manufacturer , im just letting people know I tested this light with a eneloop, and only got 28 hours runtime , which is nowheres near the 80 hour runtime specs the company listed. I would hope my info, could help some people. This was a learning experience for me also, because I now know, that any light I purchase, for long runtimes on moonlight mode , will have to be using a eneloop battery .
Like Energizer Lithiums? I saw those æons ago, and got sticker-shock. No idea if prices went down, but I stopped considering those for my AA uses a while back, so I can’t speak to them either way.
For eneloops, I think my idea of converting a multi-LED light via chip-resistor might still be the way to go.
Hell, an XM-L2 on a star might easily replace the LED board, and give you the latest as far as efficiency. I wondered before if making a mule out of one of those would be any good. If you want a dedicated firefly, that’d be ideal.
Frankly, most “normal” people just pick a combo charger+cells pack off the pegs at Target, Staples, Radio Shack, whatever, usually whatever’s on sale. They don’t have a clue about self-discharge, etc. All they know is, “battery stops working, stick it into the charger, wait, reuse”.
So they’ll get Ray-O-Vac (really nice AA alkies, and cheaper’n Energizers/Duracells and work just as well), or Energizer, or whatever was RS’s house-brand of Ni-* batteries.
And they all work fine.
These are the same people who still use 2×AA flashlights with PR2 bulbs, bought from CVS or Target or Lowes, but don’t want to keep buying’n’tossing alkies ($$:money_mouth_face:.
And for them, they’re fine if not fantastic in doing what’s claimed, namely, replacing AA alkies with cells that you can charge’n’reuse over and over and over again. And the incandescent bulb doesn’t seem to care about 1.2V vs 1.5V, at least not all that much.
Don’t make the mistake of thinking that all those 85s out there go hanging out at BLF and other places on the interweb, researching rechargeable cells out the wazoo before buying The Best™, because they don’t.
