Micro-Textured Lens for Solarforce Flashlights
I'll be interested in a few, but have to take measurements this evening at the earliest. I want 2 for the Lumintop Prince (brass & copper) but they may take your standard 20.4mm x 1.5mm size, then I'll have to check if 1.5mm thickness is ok for the Pineapple. Definitely would be interested in a couple more (OTR M3, M6, JetBeam Jet I/II MK, etc.) but have to check thickness's if 1.5mm is ok in them as well. I have no shortage of lights
So for a 40mm wide, lens, I calculated $11.42, plus shipping: 20*20*3.1415*.0075 + 2, if I did this right.
For the mathematically challenged:
diameter
(mm)
14 - $ 3.15
15 - $ 3.33
16 - $ 3.51
17 - $ 3.70
18 - $ 3.91
19 - $ 4.13
20 - $ 4.36
20.4 - $ 3.00 S2/S2+
21 - $ 4.60
22 - $ 4.85
23 - $ 5.12
24 - $ 5.39
25 - $ 5.68
26 - $ 5.98
27 - $ 6.29
28 - $ 6.62
29 - $ 6.95
29.4 - $ 4.50 Solarforce L2x (includes o-ring)
30 - $ 7.30
31 - $ 7.66
32 - $ 8.03
33 - $ 8.41
34 - $ 8.81
35 - $ 9.22
36 - $ 9.63
37 - $10.06
38 - $10.51
39 - $10.96
40 - $11.42
41 - $11.90
42 - $10.39 Convoy C8 (includes slightly thicker o-ring if needed)
43 - $12.89
44 - $13.40
Well I’m definitely interested in a Pineapple lens. I think the 1.5mm thickness will fit ok, but it may take a little thinning of that thick led centering ring to make it all tuck in there, and I’m not sure what that would do to the beam, but I’d still like to try it.
I’d buy 2-3 pineapple sized lenses.
I got my 3 S2+ lenses today.
Tested in a convoy S2+ with XP-L HI and SMO reflector, the beam appears to be much improved. The outer ring is completely gone and the yellow center in the hotspot is way less noticeable. It also gave back my 1A emitter the pure CW tint, which used to have a yellow/green shift when the convoy AR glass was in place. The MT glasses are also much clearer than I expected, the texture is extremely fine and almost unnoticeable.
Excellent glass even if you don’t need the MT feature, the lack of tint shift and high transparency alone is worth it. :+1:
Would love to have this glass in my skillhunt H03R headlamp (much smaller than S2+).
I’d be very interested in three (3) 28 mm lenses.
Thanks.
Since I don’t think the custom lenses will use a full sheet of material, I’m going to have the custom sizes cut and the remainder of the sheet will be cut into C8 sized lenses.
If you haven’t added a post saying you’re interested, please do it by tomorrow night (12/04). I will PM everyone who is interested with instructions.
I plan on submitting the sizes for cutting on Wednesday (12/07) and should be able to mail the lenses out the following week.
After I have submitted the sizes to be cut, the custom sizes will no longer be available.
Lens size application chart <—- click
I put a MT lense in a Solarforce L2M host running a CustomLites XPL-HI de-domed emitter (V2 bin, 1A tint), SMO reflector. The new lense eliminated a small, pesky ring at the spot/spill interface. Now the spot is even and slightly feathered at the edges, and just looks fantastic.
I'm very pleased with this upgrade, and want to thank Randy for developing this lense and bringing it to market. Good stuff!! :) :) :)
-Ben
miswas
I'd like to order two (2) C8 lenses, please.
-Ben
miswas
I’d like three for Surefire 6P.
Thanks!
I’ll have to measure a few lights. I’ll start with 2 pineapple lenses (15.9mm) and two 12mm
2 x 12mm
2 x 15.9mm (pineapple)
I’ll messure out a few more.
2 x 20.4 – $ 3.00 S2/S2+
3 x 29.4 – $ 4.50 Solarforce L2x (includes o-ring)
Adding a few more
2x 12mm (aaa lights)
1x 15.5mm (thrunite T10t)
2x 15.9mm (pineapple)
2x 17.5mm (firefly)
I have sent a PM to members who were interested in the custom sizes of the MT lens… if you are interested and didn’t receive a PM, contact me.
Payment deadline is Wednesday. After this, the MT lens will only be available pre-installed in one of my flashlights (no custom sizes).
Order placed and pp sent. Thanks for doing this Randy! I know this sort of custom order stuff is time consuming and probably not very profitable. We definitely appreciate it!
No pm here.
I probably hit ‘preview’ instead of ‘save’… you should have it now.
If anyone needs more time to measure the lenses you want, just let me know. The order doesn’t have to be placed on Thursday… I can do it later if needed.
Order placed for 1 each of the following:
15.89mm
19mm
P60
Payment sent.
Thanks Matt
