Sadly I think this is an effect of “flipping the die over”, aka not having bond wires. Since all the LED’s that have that also have tint shift, although nicha seems to have figured out how to minimize it.
I'd hope the nasty green tint is more a result of the true tint of the LED, hhmm, 4500K is maybe an E4 kit, so maybe it's a nasty 4C tint? We are rolling the dice with the tint on these E3, E4, E5 kit ratings.
I’d agree but the nasty green on my G3 was only the spill. Otherwise the center beam was mostly acceptable, though not actually 4500k. These are from Cutter, so no question of accurate bin reporting either.
My theory:
It is not the flipping of the die that does this, I think, but the type of phosfor, Cree used to have very fine-grained phosfor layers and was not very good in pleasant tints and better CRI, now their tints are improving and that coincides with rougher, more loose phosfor layers, that also are better in photon extraction at high angles (these angles in the old type of phosfor layer emitted much less light, photons were at the exit reflected back into the die, which was enhanced by dedoming the led) unfortunately that light at high angles has a higher proportion of longer wavelength photons and it creates the huge ugly yellow-ish corona around the hotspot (which is not spill light but light coming from the deepest part of the reflector).
Btw, TA, I stole your address from Clemence’s picture (a bit un-ethical, I know :innocent: ) and have sent you a small flashlight with very constant measured output (after 10 seconds basically constant, within 1%), so you can compare your calibration to my ‘djozz-lumen’. Not because the ‘djozz-lumen’ is neccessarily any better than any other people’s standard (I never had it officially measured, it is just my own baseline that I keep as constant as possible over time), and not that I wish you to use it (your standard may well be closer to reality than mine), but just to get an idea on how your emitter tests compare to mine in the past.
I hope it arrives at some point.
Great idea.
Thats a fantastic idea!
I was hoping at some point we could test the same emitter (perhaps the 219c’s we are getting from the same reel) but this would be even better. At the very least I could apply a multiplier to the emitter tests so that my test would be comparable to your back log of tests.
I see some PM’s I am guessing you are one of them, I will read them in a min.
The phosphor layer could be the cause as well, it is really hard to say since the phosphor change happened at the same time as the die flip.
Although it appears everyone is going to this new style, the nichia 319 looks interesting because it might have the high output without the tint shift.
I really have some hopes for the 319A, not that it will beat the XP-L(2) in output but that it will produce very pretty beams, also under Carclo optics.
I’m considering painting the deep part of the reflector matte white sometimes, so that it will mix with the spill.
Or just use a matte white spacer gasket with a high collar.
Not sure yet…
Anyone tried slicing the dome on a G3? Does it improve things at all?
Paining the lower part of the reflector is an interesting idea. I have a ton of spare S2+ Reflectors from swapping in TIR’s lenses, I might try that if I can come up with a paint to use and a way to apply it.
The light has a 4000K 80CRI (Samsung LH351B) led which strictly spoken just gives a correct comparison for that that specific spectrum (can be translated as: colour temp/CRI) and does not see possible differences in wavelength sensitivity for our set-ups (which is dependent on the quality of the reflecting inner surface of the measuring device and on how correct the wavelength sensitivity of the luxmeter follows the agreed Vlambda curve). In other words, a cool white led and a very warm white led may have a somewhat different multiplier between us than the 4000K 80CRI led that we calibrate at.
If you use flat white paint, that light is not lost but will be fairly evenly distributed in the spill.
Yeah, my idea with the 219c’s was we would 100% know they were the same bin/tint for both of us and thus be the most accurate comparison.
This light is an even better idea though. I am curious to see what the results are.
Yeah, it should also scatter it into the main beam and could improve the main bean tint as well if it is a very matt finish. The issue is how to get a pure white, flat matte, paint that can be easily applied with precision.
Maybe a markout market for “erasing pen ink”? Any good ideas?
Is Tipp-Ex something that is known over where you are?
I believe it’s called “white out”
It’s very good for this purpose because little light penetrates it, but is reflected.
Iḿ only worried about how good it will stick to reflector surface and without cracking (crackling?) over time
Maybe ‘monodek’ latex wall paint is better
Yes, white-out was what I was talking about, the brand name escaped me.
Or it just hit me, what if I made an extra tall centering ring that covered the base of the dome, I could even make it too tall and sand it down as needed. Could this work basically the same? It would reduce total output more then painting the reflector obviously but would be a heck of a lot easier.
That’s what i meant with ‘high collar spacer gasket’.
But how to get the nylon or plastic not translucent and matte / flat?
Or is that ‘splitting hairs’?
