The 105c gives me 2.8 and this one gives 2.91 with a 4.05V Rev.Jim. The low is a really nice single lumen. To me, the leads were easier to solder than on the 105c. Just a bit more room. I went for three mode, LMH with no memory. I really like this driver a lot with all the different setup choices.
I just replaced the driver in my MF UF 3 mode with one of these. No way to measure current at the led but I'm seeing 3.04A at the tail with a freshly charged (4.21v) AW IMR and 3.00A from an AW 3100 at 4.07v. I'm pretty happy with these results since I was seeing 3.8A+ from the 3100 and 4.5A+ from the IMR with the original driver. Hopefully the heat and output sag will be reduced. I also like the low. It seems to be about perfect for reading a map in a dark car without blinding the driver or looking for something in the bedroom without disturbing the wife's sleep.
The OP writes: "The mode memory snaps in about 0.5-1 second after a mode switch. I normally prefers memory after switch-off so I do'nt have to tap twice to shift level."
In a KD review is written: "I would rather have it switch modes with a single 'off/on', but it takes two 'off/of' cycles to switch modes. Not really a big deal, maybe even better. Just used to switching with a single click is all..."
Two taps to switch modes when the light is on? Or just one?
And what about memory - what does it mean that it "snaps in about 0.5-1 second after a mode switch"? Only that if I switch the light off less than 0.5 a second after a mode switch it doesn't remember the last mode or anything more than that?
Do the answers to the above questions change if I disable mode memory?
I have memory disabled so that it starts in high every time but the way I understand it is that it will remember the mode if left on in that mode for .5-1s. In order to switch modes you have to switch off then back on (to clear the memory) then quickly switch off and back on again to jump to the next mode. I'm not sure what happens if you switch modes and then turn it off within .5s but my guess is that it would start in the next mode when you turn it on again later.
Has anybody tried making a sandwich with these drivers? I'd like to make a 3 board sandwich with the 3A version and I was wondering if a single mcu would handle all 24 of the 7135s?
anyone tried programming the PIC12F629 with their own code? I seem to have problems communicating with the chip. I checked my connections, but all seem ok. could it be one of the components on the PCB that prevents somehow the programming signals from working correctly?
I gotta say, I love what you listed as a con. I loaded up one of the 3040 mA version with a XML U2 in a p60 and using the panasonic 3100 cells, the ultra low will run for hours and hours and hours and put out enough light to read by, read a map, check on sleeping kids, etc. If I find anything is wrong with the driver, the medium is too close to the high. If I could, my alteration to it would be to keep the high and low and lower the mid by about 1/2.
Well, not the prettiest idea but if needed to remove a single or few amc 7135 chips i simply crushed them with pliers and carefully removed the leftovers. Works.
I'm just exploring options. Right now I'm running mine basically DD using the UF XM-L P60 driver and according to my meter with 10ga leads it pulls around 12A (4A per emitter) at startup off of a fresh imr. I figured 9A from a 3 board sandwich would make for a nice "wow" or turbo mode leaving medium and low for normal use. Though I guess I'd be better off to keep it below 2C from a 4000mah cell so it's not limited to running imr. Maybe a 2 board sandwich with some extra 7135s to push it closer to 8A on high? Anyhow, I was just curious if there is a limit to how many 7135s a single mcu can handle if I remove the mcu from the other board and slave the "dummy" board to the board with the mcu?
I find the low to be on the bright side!!!!!!!!! lol? Its still significantly brighter than the low on a D10/EX10 ramping, and about the same as the low on a D10/EX10 SP.
I have mine in a skyray G6. removed 5 of the 7135's to leave 3 behind to provide something I'm guessing to be around the 1.2A mark for an XP-G.
Mode spacing for low/med/high is not bad at all IMO, a low that is *FINALLY* low enough to call a low (IMO), a medium that is not too close to being a high, could be a tad lower, but not bad at all, and plenty of power on high. Im currently running mine without memory, and on grouping number 1, so I can get 2 sets of l-m-h, followed by the disco. Because of the lack of mode memory, this works great because I rarely have to see the disco unless I actually want to.
Pretty happy with everything except the fact that it is still "on-time" memory. Off-time memory would have made this perfect. This means that if i don't turn it on for more than a second, it will go to the next mode next time I turn it on. In other words, if I were to pick up the torch one day, I cannot always guarantee that it will start on low. This does annoy me, and is why I prefer the off-time memory, in addition to the fact that mode switching requires double tapping initially.
I bought the 3A version because I get a good supply of 7135 chips for practically 10c extra over the lower current models. I find them easy to remove too!, just use 2 soldering irons that are well tinned and a "helping hands" alligator clip on a metal base to hold the board. Heat up the heatsink tab with one iron, and the 3 pins on the other iron, and when its all heated up enough, it simply slides off, usually done with a couple seconds with no collateral damage at all.
So would I buy more? likely, but I only have 2 torches that actually need replacement, the rest already have UIs that I'm happy with.
For anybody that wants a brighter low, simply break the trace to the Vdd pin on one of the 7135s and solder a jumper from the Vdd pin to B+. This will put that 7135 on full all the time so low becomes roughly 380ma. A word of caution: Only do this if you're using protected cells as this will defeat the driver's low voltage protection.
Good news I just got a chance to take apart a Shiningbeam P-Rocket and it had one of these new drivers and I was able to reflash it with the standard setup I have been using on the old Nanjg drivers.
