M22 will be dedomed /w fet driver, the result is like 1700lumens and 90k cds, its some kind of a luxury X6 of some sort, the beam profile is virtualy the same yet the heat disipation/the host is ways better
M2X will be modded the same way, the result is 250k cds
M3X i apply only a modest driver mod( 5.5 amps at the emitter) and i pot/ heatsink the driver, its kind of a fragile one( from experience), several ot those M3X will be XPG2 moded ofc
The solder connections on the big ground tabs is what I did. I’ve read that about the AMC7135, someone confirmed this by testing but I can’t remember who it was. Problem with that is, there are many sources for those AMC7135 chips and we don’t know if every chip acts that way.
Spacer from kiriba-ru , Carclo 10622 optic , Nichia 219C 4000K CRI 90+ D240 leds and old dsche copper quad mcpcb .
Stock driver , with bypassed spring . Also added the second LED & Resistor in the tailcap PCB . Leds on mcpcb is soldered on the spacer and spacer inside the head too .
Unfortunately i don’t took pictures during the mod , i had my phone for repair .
But here are the results :
Pulls 12 Amps from the little Efest 14500 V2 650mAh :heart_eyes:
You modified the Blf-A6, a FET+1 firmware?
I’m running a S2+ with 3x 219C and FET+1 (modified Blf-X6-driver) as EDC, of course it gets hot fast in turbo, but with a “not-too-high”-drain cell like Sanyo 18650GA its really usable.
Yupp, but nothing major. To add the OTC I changed the OTC pin to be the one next to the GND pin, so that I can solder it across those two pins. Also brought Battcheck_VpT to this firmware a while ago.
I built this zener modded FET driver, using an Attiny13 from an old 105C type of driver (one without stars, mode group with/without blinkies sekected after a flash in low mode).
Long story short: I first tried to zener-mod (swapped the diode for a 220 Ohm resistor and soldered the zener parallel to C1) the BLF-A6 driver, zener-mod worked but the user interface was messed-up bigtime, then teied to zenermod a AK-47C but it did not work, probably because the circuitry is a bit different from the 105C. So for the third attempt I built the driver from the picture because I built that one before and it works, except that the low voltage warning kicks in at 3.5V.
I used this driver together with a (my only) Nichia 144A SM453 in a S8 type host, modded the tail section a bit to accomodate 2x 18350 batteries. The mod was succesful, got a bright working light!
I hoped for 3A but the voltage of the 144A is so low that on those two little cells it drawed 5.8A, way too much for this led on the non-DTP board, the output was way over max.
Before something went wrong I made these shots, first a lens projection of the die, then a beamshot from 2.5 meter to the wall. As can be seen the die looks fairly ok (much less ‘spiegelei’ like some of the earlier samples), but the beam from the small OP reflector still has an unpleasant yellow hotspot. The perhaps bright side is: a distinct spot without donut hole.
I had to take the pictures on high setting to avoid pwm effects, and the 30 seconds on near 6A appeared too much, the led got too hot and died
Exit 144A led, I was too careless. I will save this host+driver for a XHP50.2
One of the first lights i bought, a Jetbeam Element E3S with potted FET+1 driver, 5D XM-L2 on T-Pad and I filed in a couple of thumb cutouts.
Also hacked a couple of Xiaomi speakers so both can work at the same time connected via a USB cable.
Only one needs to be powered up in operation so when the battery gets low just switch over to the other one :sunglasses:
rebuilt a dead emitter S41S head today. Used 2X XP-L HI V2 3A and 2X XP-L HI V2 5A2
Guess I shoulda put the different tints opposing. Was concentrating on getting the XP-L HI polarity right more.
I used the last version original MCPCB and made sure to reverse the polarity of the emitters and wires. Used solder paste on the board to the head and screwed it down (no washers) before it cooled. Used 18 AWG and wanted to bridge the negative wire over to the back tab of the FET and the FET moved almost instantly. Bad solder on the other 4 legs, Got centered again and made sure the legs were now soldered down, Neg wire bridge was successful. That made me take a better look at the New BG A6 driver and found weak legs on the MCU.
Tried the original X6 driver but it kept kicking out of the higher modes with a double flicker and went to lower mode. The beefed up A6 is doing great so far.
Really like the tint in all modes. Blends well, not the 50/50 shades I thought might hapen.
