Will that tube screw onto any of the heads?
Thank you Dale for all the information regarding your experiences with modifying the PT series, Mecarmy should supply you with free samples.
LightRider, it should. I’ve had the PT10, 14 and 16 and they were all interchangeable. So say if you had bought the PT14 with 14500 cell and then buy this tube from illumination Gear then you’d be able to use the one head with either cell type, actually 3 cell types as the 16340 still works in the 18350 tube.
I REALLY want one of the MecArmy Limited Edition lights, but they’re insanely expensive, $1700 I think. The details are exquisitely rendered, amazing.
FWIW, my Aunt confiscated the PT14 and my wife took the PT10. sigh.
Wow! That’s not even CLF range!
Hey, “The absence of lights means the presence of more.” Quote, LightRider
Have you seen their limited edition’s? They look like Bamboo shoots, with the cracks and holes and knuckles where roots were coming out, darkened in the cracks and the knuckles are gold plated, the entire thing is done in Titanium. The detail work is incredible.
Takemitu = Take me too… it’s calling me, see?
Seems like there were only 10 made of each one, worldwide. So I’ll never see one, as if I had that kind of money anyway right?
Ok, so by now y’all KNOW I really like the PT16, right? So I’m gonna get me a PT60 for sure, and if it makes 9600 lumens with XP-G2 emitters what will it do with XP-L W2 1D’s?
Next couple of weeks….
Dang thing is gonna cost me another $100 to buy the XP-L’s… Ugh!
Shoulda left well enough alone, just re-discovered the PT-16 in brass. OMG! Aluminum reflector! Geesh, why is it priced so high? Me want me want! lol (incorrigible I know.)
I got the 18350 battery tube in today from Illumination Gear, worked just fine although the charger portion was a bit different. Didn’t really matter as it came out anyway. I took the new tube and head out to the shop and bored the top of the battery tube where the charger sat so an 18500 could slide through all the way, then I made a couple of brass rings that would fit around the cell and act as spacers top and bottom, 1.2mm in the head and 2.4mm in the tail cap. So now it’s like a twisty, the tail cap screws down onto the cell and if it weren’t bottoming out on the brass spacer it’d crush the cell. No springs either end, direct contact.
So now it does a whopping 3041.7 lumens on the 4 XP-L W2 1D emitters. Crazy little dynamo it is, lights up a room bouncing it off the ceiling!
That is a lot of lumens for a 2x 26650 light. Wow, when you stop and think about it! I still haven’t cracked my pt14 open yet. It’s still in the plans though.
Yeah, seeing that much light coming from a single cell palm sized little pineapple looking light is just mindboggling.
Has anyone else swapped emitters, or modified their PT series light recently?
My 18 gets all the use since putting in the 219B sw40s from I.S.
The lumens are not missed, Turbo is still more than needed for most purposes.
Not sure why but that reflectored version really really interests me. Probably copper or brass, as much as I like Ti I wish they’d kept the same design. So the copper one, ready to handle whatever I throw at it, is probably where I’d go if monies were there for it.
I have mine running on a 18500 by using a pair of brass rings, one on each end, to act as ground spacers. This let’s it do some crazy lumens which is just giggly insane from such a small light.
Is that an optical illusion or does the Ti PT18 have a larger dia head? Looks pretty sweet, for sure, perhaps such a light would be best left in stock trim and just enjoyed for it’s sheer elegance…
I think its just the camera angle that makes the ti head look larger.
copper is available w 18350 tube…
Caution: clicking the pic, can can lead to pain in the wallet LOL
here is” a brass one”:http://www.ebay.com/itm/Blackwater-SR71-Bs-3x-CREE-XP-G2-1000lm-USB-Rechargeable-LED-Brass-Flashlight-/391525494017?\_trksid=p2385738.m2548.l4275 for cheap, but, its conductivity is less than aluminum afaik
Nobody should bring up this thread ever again! I just really love these PT-series lights! They just keep calling to me.
And Dale…
C’mon… expect us to believe that?
I didn’t say I would put 3 XHP-50.2’s in it, did I?
I do love these little lights though, such magnificent wow factor… just gotta love it!
And the “equivalent” sr-series doesn’t match up. In my opinion anyway.
there are a couple of differences that might matter to some
advantage SR71
Prices are similar for the anodized version, prices are lower for the Brass and Ti SR71 than the PT16.
The SR71 spec says 5 lumen low, PT16 says 10 lumen (I don’t know if the specs are accurate)
the anodized SR71 seems to use a reflector with glass lens, PT16 has the plastic TIR
the SR71 has a smooth head and tail so easier on pocket wear, PT16 head has cuts in the head to create fins, and the triad tail is more likely to gouge a pocket.
advantage PT16
No copper option for SR71, yes copper option for PT16
SR71 has memory and does not start on low, the v2 and v3 PT16 starts on low, no memory.
equal
both SR71 and PT16 v3, are 18350 compatible
The triad tail, pineapple knurling, and finned head are all what makes the design work for me. The SR71 loses out in the design department… if I were buying a copper or brass version it would be in the PT16 style, surely not the SR71.
