Thanks, guys - it’s good to know people find it helpful
The reason I haven’t done an updated version yet is that there’s only one Convoy light available as stock with the new driver. That’s the clear-anodised C8 with XPL HI LED. Everything else is special request or DIY. I’m basically waiting to see what other stock options come out so I don’t waste my time crunching numbers for the wrong stuff.
Having said that, here are some rough and ready figures for a current-model S2+ with an XML2 T4-7A LED and a new driver with 8*7135, which I gather you’re considering:
Your Thread has a ton of good info in it…. all compiled in one easy to read & see reference. You must have put a load of time into compiling this, thank you again for sharing it. :+1:
I hope at some point you’ll post it here on BLF. As far as I am concerned it should deserve “Sticky” status.
I have a T4-7A S2+ myself, so you got me wondering what the Biscotti mode levels would be. The way to get me to answer questions is always to pique my curiosity!
While I have you, I have one more question if you don’t mind. If I get the 7135*6 2100mA driver, how long could you run that on high before it becomes uncomfortably hot?
Your chart suggests the high lumen output for 2100mA is 550 lm. There are times where I may need to run flashlight at the brightest available for 30 minutes or more. My thinking is, I could rund the 2100mA on high for a longer period of time than the 2800mA and it would be brighter than stepping down the 2800mA to 50%. But I’m not sure if 30 min. on high is too much for the 2100mA.
I wonder: given the tint comparison chart, what tint looks most like an incan lamp? I thought it was the T4-7A, but the picture makes it look like it’s an incan on a brownout. The T5-5B seems closer to what I’m looking for.
(if someone could tell me the CRI on those bins, I’d love you to death)
That is AWESOME information, elwood, thanks a bunch :laughing: :+1: Finally I can get a Convoy with a non-blinky Low mode!
I was going through the same dilemma and read the same very useful info.
Personally I use moonlight 90% of the time when indoors. I have the 8*7135 version. The next mode 1% is already too bright for me.
Not sure how a 0.1% moonlight will be in your 4*7135 version but another idea would be to use a RED difusor, Simon had a bunch of colors but I thought red is great for night vision,
With a difusor you might be able to use a higher mode without waking up your family
From my calculations (likely off, as I’ve used a linear proportion between current and lumens, but it serves as a baseline), 0,1% moonlight on 4x7135 should be about 0,5lm. Good enough for me myself.
I use an old S2 w/2.1A driver as my EDC and frequently tailstand it on my dresser in the morning while getting dressed so as not to disturb my wife. I had the original “2-group” driver with the annoying low mode blink & memory. I used to have an old XM-L T6 4C in it, but changed it over to an XM-L2 T5 5B1. The 5B1 is without doubt my favorite tint and the one that most realistically represents colors to me.
I finally got my self setup and educated to flash my own firmware and flashed STAR (regular on-time memory). I set it up with no memory and modes of: 3.5% - 34–100. I found low was still too bright and “on-time memory” (even on a driver with “no memory” since it affects mode changing while the light is on) was really driving me crazy! So I added the off-time capacitor and reflashed STAR Off-time with low adjusted down to 1.4% (I aimed for 1% and actually got 1.4). The off-time memory work fantastic (exactly as expected) and now I know what all the rave was about! Low could still be adjusted a little lower though. I am one that does not light “moonlight” (i.e. a barely glowing emitter that doesn’t hurt your eyes to stare into) as I see no real purpose for it (not for me anyway). My guess would be that something around 0.5 output in my case would be ideal. It’s really nice being able to tweak firmware and reflash drivers to give you exactly what you want!
About your decision on which driver (2.8A vs 2.1A, etc. . . ). I agree with others that you can always choose a lower mode and only use max as needed. With custom firmware you could create a “Turbo” with or without a timer (I’m out of the loop on temperature sensor firmware) and have high up around 75% or so where turbo is barely a step up for “max” while “high” is your normal able to run unlimited time high mode. My S2 at 2.1A will get hot on high after a minute or two, but it’s not scalding. I’ve never tried to keep it on high for long periods of time though. (I have discovered it in my pocked switched on by accident and feeling hot.) I know user Comfychair has posted up that he would let similar lights (like S6, S3) run on high (2.8A? not sure) sit and run for long periods to prove that no damage was done and that the bodies could handle the heat. I feel the 2.1A version is a good level for the S2 and good balance of runtime with output (2.1A draw on a Panasonic NCR18650B 3400mAh cell tested at 3,128mAh @ 2A draw would yield approximately 1.49hr runtime (3128/2100=1.49) and I calculated 470 lumens out-the-front in my D.I.Y. sphere on my previous XM-L T6 4C emitter). I will be retesting my S2 again in the near future. I also need to get back to my sphere work and analyze how my sphere calibration is working out.
I don’t have any 7135*6 driven lights, so I can’t answer that with certainty. The best I can do is point you to my discussion of S2+ thermals on CPF. My estimate was 3 minutes 45 seconds, but you have to understand and agree with my method before you can adopt that figure.
That’s really odd. If i check the link in that original post, it links to the correct place. But if i check the link in a post where i was quoted, it links to the jirotv crap. Not sure what’s going on but this is the original link: http://s20.postimg.org/fuqwlhopp/Convoy_Side_By_Side_Tints.jpg
Go back up and look at post #26… ‘dingdong’ changed the links when he quoted you ‘elwood’.
I guess he had nothing better to do on his first (and hopefully last) post here on BLF………… :person_facepalming:
————————————————————- EDIT: You will notice your links still work fine when quoted in posts #4 & #6
I haven’t got any incans to compare with, so I can’t help you there.
When it comes to CRI, the XML2 datasheet says “Typical CRI for Warm White (2600 K – 3700 K CCT) is 80.” CRI-binned stuff is available at up to minimum 90 CRI in the T4-7A range, but I doubt Convoy will be spending the extra money for CRI-binning.
