I always look at things from the widest possible view and try to pick features / options that will work for as many different possible situations as possible with as little work as necessary.
In this case it would need to be able to work with a low Vf LED where it will limit the PWM at full voltage and with a high Vf LED where the PWM does not need to be limited and only increased to maintain output in the mid range modes.
Basically the way everything works now is fine, the idea with this feature is to allow the modes to maintain some semblance of regulation as the cell voltage drops. The modes as they are at full voltage is fine and if the mode is high enough that it can not “maintain regulation” past a full cell, then so be it, that is the price of using turbo modes.
I never hear of people complain about the modes as setup for a full voltage cell like they are now, so I figure why change it, plus it will make setting up the ramp table and modes much harder in the software because you will always have to factor in the multiplier instead of the multiplier only trying to maintain output as voltage drops as best it can.
From the way I understand it basically flipping your code around so that instead of removing PWM as voltage increases it would instead add it as voltage decreases. Same thing, just reversed and allows all the modes to remain unchanged from how they are now because most of them are indeed setup for full charged cells. Otherwise we will have to increase all the PWM by 30% only to remove that 30% in the software regulation later.
Strange, looks good unless there is a minor short someplace or in one of the 7135’s.
I have never measured the narsil drain myself but I think tom has it under 1mA now. No idea myself. I might check one of my lights to see what it does.
I just checked one of my Narsil triple drivers and I got 5.3ma, so actually seems like it is working fine. Just not sure why it is so much higher then the normal narsil. That would be a question for Tom.
Hmmm? I’ll look over everything again. Maybe he has not tested parasitic drain on the triple channel version? If I can rule out a software bug then it must be something about the driver itself. Otherwise is there another eswitch firmware for the triple channel drivers?
Ah… that helps much! Thanks. I’m not sure if I can live with that or not? The light will eventually go to a paying friend so I don’t want it to drain the cells on him. I’ll have to think about that.
Yeah, I didn’t expect it to be that high either, no idea why it is that way. Although in my case I only have narsil drivers in SRK’s, L6 and a D01, all of which have enough batteries to last a few years at those drain levels lol. Just not a big e-switch guy for the smaller lights.
I gave it a shot with BOD disabled as well but I get the same result. 4.6ma.
4.6ma is with power supply voltage at 3.8 btw. So my number lines right up with yours. Makes me pretty confident it’s a firmware issue.
Edit: Tom did say he has a v1.3 completed for Narsil triple. It has no dividers and support for an indicator led on pin 7. He has yet to post any links though. I wonder if the parasitic drain was addressed in the latest update?
Yeah, the base idea is great, it would just make is simpler long term and more widely applicable by having it increase PWM instead of decrease it. Increasing it is applicable to all FET modes, decreasing it is only applicable to the turbo modes.
I have an OTSM implementation working in bistro with BODS, and it fits a 25. 2018 bytes, without trying to squeeze yet. (includes all recent changes)
Now when I say working, I mean the software does everything it's supposed to. I'm just testing by shorting pin 7 to simulate a power-down. It detects the voltage drop, sleeps. It wakes on watchdog every 250ms just to mark time, and finally it wakes on power pin rise and restarts the code without delay. I'm using ram persistency to get debug info even through minor power downs (basically like bistros OTC-less OTC trick). Basically I've verified all the steps are working and in the end it reports back to main code how many loops it slept through and I'm translating that straight into a "cap_val" variable so everything else is the same from there. The code is skirts the edge of the rules , but it works.
That said, I have no solid idea how well it works. I know it's pulling about 6~7uA throughout the sleep loops (this is a little better than with the ADC but only because using BODS has the current so low anyway) . From what I'm seeing I suspect it wastes about 10uF of capiticance just getting shut down and right now I'm just quite understanding my hardware situation with that, but anyway, I'm aiming for 40uF and I think should probably get there. I don't have 40 now and I don't have a low voltage chip, so I'll have to work on hardware to get it going now.
I'll be happy to post highlights of the new code if anyone is interested.
There is a much better reason in my opinion and it's the main tradeoff I've been arguing about which approach to use for targetting these PWM curves. The reason is if all the FET modes have 100% 7135s plus some PWM level on the FET, you are guaranteed that all the FET modes, regardless of low the PWM level is, are higher than the ALL7135 modes. If you didn't do that a mode that started out above all 7135s at full battery would end up below all 7135s with a weaker battery. You'd get mode orders that change with battery level and the number of 7135's you have. However, once you're doing voltage correction, this argument doesn't go away, but it gets better and other arguments favor well, not FET only, but PWMing the 7135s with the FET. There's still pros and cons either way there though.
The FET can handle the current. Although, sure, spreading heat a bit helps too.
I thought a little about testing power off detection times to help optimize them. The thing is you need to measure start time well, which means you need the mcu to shut the power off itself. I was staring at the 7135 pads, it might just be possible to wire one sideways for this purpose. It's a bit of fuss just to get some tests though.
Good to hear you have some bistro based OTSM code coming along!
As far as the regulation goes, I am not understanding what you are saying.
The FET modes will indeed always be higher then the 7135’s, this is how it is designed, how it should be and I don’t see anyway where this will not be the case unless the ramp table is vastly changed around.
You only ever bring the FET online after the 7135’s are at 100%, thus the FET can only add power to the 7135’s not subtract it no matter what the FET PWM is.
Let the 7135’s regulate best they can using hardware and let the software try to improve the FET best we can. We are not going for perfection here, just improvement and trying to not waste all that extra duty cycle on the FET modes.
Mostly I was just pointing out exactly what you just said, that yeah, if done that way, it keeps the modes in order. That's why their doen that way. But things are more complicated with voltage feedback. You say leave the 7135s alone, but you're not leaving them alone. When you change the PWM you're changing the amount of time speant in 100% on AND the amount of time speant instead at 7135 ON level. You're changing both. If you want to think of it like you're just changing the FET duty cycle, ok, but that's not the case, you're changing both duty cycles, and in a way that's more non-linear than changing PWMimg it all together. Anyway, it can work either way. if someone writes up some code that works with multiple levels or just a turbo for low vf leds, and has defines for both adc modes and does it that way, great.
For the otsm the biggest thing is right now I'm just using ram to store the sleep data. That's ok if you wake back up, but if you dont' the ram gets corrupted and might sometimes look like a valid short sleep time by accident. So that gets a proof of concept working but it's not ideal. I either need some ssymbly magic to let me initialize the variable but jump past the initialization on restart, or I'll have to revert to eeprom, but as it's on every click, it needs wear leveling. So a little left to work out to really polish it off.
