Nice :+1:
(could do with some black on it though) :laughing:
Thanks CRX,
That Mi7 looks awesome too. I really like the Trit SW and the highlights around it.
I have well over an hour in that tube getting it to present form. The tubes were knurled and I guess they weren’t up to par. Knurling was ground off, but still had signs of it left and not too smooth or round. Had to refinish the whole light to match. Also dropped a hot XP32 board on the floor and wasted all 3 emitters as it fell flat on the domes. I was ready to go back to bed and try getting up on the other side. Was a wake up call and another coffee later, things went better. Happy with the build.
That’s why i always butter the underside of the MCPCB
This is the picture that goes with my earlier post : What did you mod today? - #2278 by Texas_Ace
Well after a year of collecting parts, building a few lights and generally having a great time on BLF I finally got down and dirty and knocked out some real lights.
Put together about 40 of them since the year started and I officially finished all of the lights I currently own as of yesterday. (well except for some C8’s, but I am waiting for a triple setup to prototype for kiriba-ru before I build those).
I had them all out charging the cells yesterday and gave them a head count, turns out I have officially joined the Century club with over 100 flashlights (some didn’t make it into the picture as I kept remembering more I had stashed around the house and cars).
So with them all out I decided to take a family picture or 5:
I think I have officially exhausted my options for budget lights at this point and my collection offers everything from 17,000 lumen flood monsters to 1000m throwers. I have a trade pending for a cometa which is one light I am missing, a mid sized zoomie.
See what ya’ll can point out, if you have any questions about the builds feel free to ask.
One of “My” days that would have worked.
Still have 2 Ti-1 tube lights from Rey. May do the BC black or bluing on one of those to get it in the blocks.
That’s some going Texas_Ace :+1:
LOL, I know it is bragging but what can I say, after a year of reseach, buying and preperation to see it all come together I am a bit excited.
The issue has proven to be to actually be able to use them all!
I am quite sure that I will be reducing the quantity before long, you just can’t use this many at once. Although it makes for one fun picture to have them all in one place at least once.
Impressive TA !
That’s a very interesting collection , especially the fact that most of the lights (should) have your drivers in there (and the fact you built them all of course)
Yeah, they are all modded with the exceptions of the few cheap little 9xled lights and the nitenumen ne01. Most of which have TA drivers as well (which is why I built them in the first place lol).
Added a momentary side switch and magnetic tail.
The light now works by pressing the side switch or tailcap for momentary on function or as a normal twisty for extended use in lower modes.
Just for grins I modded one of my Thrunite TN42’s with a XHP70 P2-1C FETDD Vishay sir800 18awg leads (+) off driver spring,Custom made driver adapter, SD75 mcpcb 12.27amps at the LED, GITD fins……GITD switch locator in middle lanyard hole…. :cowboy_hat_face:
That’s pretty sick!
Any lux numbers?
Started on a copper heat sink for an SRK. The cylinder was .5 mm copper sheet and the heat plate 1.8mm copper. I’m pleased with how it’s going, the 15mmL x 41mm D is both nicely round and flat even though hand wrought and brazed. With a MtnE FET+1 driver it will need it. The other item is a 1.4A driver modded for bistro. 1 chip is segregated and jumpered to pin 5 and each of the other 3 doubled up. Also a cap bridging pins 2&4 for OTC. Basically a bistro compatible single sided board that’s regulated. The host is a sweet little grey S2+ modded to a 16650 triple 219C but at xx500 length. Wood tube of course. I’ve shown it before but finally close to finishing it. I didn’t want to give up retaining ring convenience and none of the 3-4 chip drivers are set up for plus one firmware.
where did you got your GITD stuff and how to get it on the flashlight that way
Dome on, reflector .020” off the board with plasti-shim, no centering ring 238kcd.
Will be making a correct centering ring out of Delrin and shaving it later, just ran out of time! Saved all the stock parts, didn’t want to alter the stock ring.
It was a bit of a PITA build!
Glow On Film…
I have the Glow paint and the Glow film. The film glows all night, just not as intense as it’s first charged, but in complete darkness, I can still see it in the morning, I think it said up to 12 hrs? I use a razor to cut strips and a Precision shim punch for dot’s and centering rings. It works great in triple/quad optic builds too. Just lay the strips or even the dots on the mcpcb, or the leads, as long as it dosen’t interfere with the legs locating, or the optic being held up off the board, it looks great thru the optic’s! The Glow film is pretty powerful, when I use it for centering rings it will cast a beam when fully charged!!
Glow-On and here is the film Purchase - Glow-On
Quads and triple Glow On film…
Switch markers tail cap ends
Centering rings, cast their own beam
@KawiBoy: Cool build and pictures! Must be 4500lm?
@Rbd: was that a 101-AK you started with? That sounds like a really nice driver
DQG Spy XP-L HI V2 1A
EagleEye X2R 18350 Shorty with Nichia 219c 5000k and lighted tailcap
and
Dunno if anyone has one of these, but the Lumintop SD26 is a real nice light. Easily fits 26700's, and worse size protected EVVA cell I have, just over 70.0 mm. Think'n it's a great candidate to run a SANYO 20700A or B cell in.
I started on the mod - will be using a TA triple driver, actually the TA 30mm TA designed for the Convoy L6, but will use a Schottky diode instead of an LDO - easy to do. The 26 mm MaxToch XP size MCPCB fits perfectly, so plan on using a XPL2 V6 2B from KD in it. Running Narsil of course, supporting the green LED's behind the semi-transparent switch cover.
There's no reviews or info on the SD26 posted anywhere, but It's a real nice 1,060 lumens (what I measured, rated at 1,000 lumens) or so compact size 26650 light.
Bezel was glued but easily broke the bind with grippy gloves. Driver was also glued down, probably using thermal epoxy, but broke it loose using a solder pick thru the LED wire holes - no damage.
