Added a momentary side switch and magnetic tail.
The light now works by pressing the side switch or tailcap for momentary on function or as a normal twisty for extended use in lower modes.
Just for grins I modded one of my Thrunite TN42’s with a XHP70 P2-1C FETDD Vishay sir800 18awg leads (+) off driver spring,Custom made driver adapter, SD75 mcpcb 12.27amps at the LED, GITD fins……GITD switch locator in middle lanyard hole…. :cowboy_hat_face:
That’s pretty sick!
Any lux numbers?
Started on a copper heat sink for an SRK. The cylinder was .5 mm copper sheet and the heat plate 1.8mm copper. I’m pleased with how it’s going, the 15mmL x 41mm D is both nicely round and flat even though hand wrought and brazed. With a MtnE FET+1 driver it will need it. The other item is a 1.4A driver modded for bistro. 1 chip is segregated and jumpered to pin 5 and each of the other 3 doubled up. Also a cap bridging pins 2&4 for OTC. Basically a bistro compatible single sided board that’s regulated. The host is a sweet little grey S2+ modded to a 16650 triple 219C but at xx500 length. Wood tube of course. I’ve shown it before but finally close to finishing it. I didn’t want to give up retaining ring convenience and none of the 3-4 chip drivers are set up for plus one firmware.
where did you got your GITD stuff and how to get it on the flashlight that way
Dome on, reflector .020” off the board with plasti-shim, no centering ring 238kcd.
Will be making a correct centering ring out of Delrin and shaving it later, just ran out of time! Saved all the stock parts, didn’t want to alter the stock ring.
It was a bit of a PITA build!
Glow On Film…
I have the Glow paint and the Glow film. The film glows all night, just not as intense as it’s first charged, but in complete darkness, I can still see it in the morning, I think it said up to 12 hrs? I use a razor to cut strips and a Precision shim punch for dot’s and centering rings. It works great in triple/quad optic builds too. Just lay the strips or even the dots on the mcpcb, or the leads, as long as it dosen’t interfere with the legs locating, or the optic being held up off the board, it looks great thru the optic’s! The Glow film is pretty powerful, when I use it for centering rings it will cast a beam when fully charged!!
Glow-On and here is the film Purchase - Glow-On
Quads and triple Glow On film…
Switch markers tail cap ends
Centering rings, cast their own beam
@KawiBoy: Cool build and pictures! Must be 4500lm?
@Rbd: was that a 101-AK you started with? That sounds like a really nice driver
DQG Spy XP-L HI V2 1A
EagleEye X2R 18350 Shorty with Nichia 219c 5000k and lighted tailcap
and
Dunno if anyone has one of these, but the Lumintop SD26 is a real nice light. Easily fits 26700's, and worse size protected EVVA cell I have, just over 70.0 mm. Think'n it's a great candidate to run a SANYO 20700A or B cell in.
I started on the mod - will be using a TA triple driver, actually the TA 30mm TA designed for the Convoy L6, but will use a Schottky diode instead of an LDO - easy to do. The 26 mm MaxToch XP size MCPCB fits perfectly, so plan on using a XPL2 V6 2B from KD in it. Running Narsil of course, supporting the green LED's behind the semi-transparent switch cover.
There's no reviews or info on the SD26 posted anywhere, but It's a real nice 1,060 lumens (what I measured, rated at 1,000 lumens) or so compact size 26650 light.
Bezel was glued but easily broke the bind with grippy gloves. Driver was also glued down, probably using thermal epoxy, but broke it loose using a solder pick thru the LED wire holes - no damage.
Dunno if anyone has one of these, but the Lumintop SD26 is a real nice light. Easily fits 26700’s, and worse size protected EVVA cell I have, just over 70.0 mm. Think’n it’s a great candidate to run a SANYO 20700A or B cell in.
I started on the mod - will be using a TA triple driver, actually the TA 30mm TA designed for the Convoy L6, but will use a Schottky diode instead of an LDO - easy to do. The 26 mm MaxToch XP size MCPCB fits perfectly, so plan on using a XPL2 V6 2B from KD in it. Running Narsil of course, supporting the green LED’s behind the semi-transparent switch cover.
There’s no reviews or info on the SD26 posted anywhere, but It’s a real nice 1,060 lumens (what I measured, rated at 1,000 lumens) or so compact size 26650 light.
Got any pics Tommy? I too was interested in the SD26, sounds good to me…. :+1:
I have been running the 20700A’s in both my modded UT 02’s and both my modded Malestrom MMUx3’s.
Yes, I do got pics - been taking them as I go, but have a ways to go. I'll post here soon, when I get further along. Should be able to fit the TA 30mm triple even with all the 7135's mounted, because there's a small driver mounted stiff spring. I'll loose the USB charging of course, but that's usual. The stock driver is a two tier design. What I like bout the light is it's compact size - the side switch hole actually overlaps with the reflector space, but there's no ill effects. The switch is mounted in the side of the light, SRK style, with 2 LED's. MCPCB is standard height, so no need to play around w/height. They use a small single screw in the MCPCB shelf simply to keep the MCPCB from spinning - it actually doesn't hold anything down -- interesting, but this is why many lights come with only one screw populated.
It's actually a simple e-switch mod - I've worked on many far more complicated.
Ohh - it also had, what I think, is a temp sensor mounted on the stock MCPCB, which is alum unfortunately. 2 small wires, 1 is ground, ran to a small SMD component on the MCPCB - they say it has temp monitoring so that's what it probably is.
Cool… looking forward to this one….!
Klarus XT12GTS
Mod is here with a lot detailed pictures
So now finally to the roots of this light. The other thread is a bit of a little hoax, its not a Klarus prototype The GTS print on it is photoshopped, but the rest is real. [image] Sadly I have to tell you it's a mod from me and will most likely never been sold this way, but it is not to hard to build if you have a spare XT11GT and put the driver of the XT12 in the XT11 just sealing the side switch and charger port of the XT11 with a spacer or sand down the XT12GTs head to make it fit …
I’ll post a review soon (when i actually have the light) on SD26 .
I upgraded my quad Convoy M1 to Nichia 219C D320 5000K and a MTN-17DDm driver with Bistro firmware :
Battery is a Sony US18650VTC6, this is the most amps I have seen in any light I have build.
How do 219c domes fit with khatod optics? If you didnt melt it yet
Thrunite T20T titanium
MTN 17mm FET+1 driver
XP-L HI on Sinkpad
15mm x 7mm round aluminium heatsink in head
Potted driver
6mm x 1.5mm green tritium vial in lanyard hole
Fixed squishy loose switch cover
Black aesthetics
Brushed finish for improved grip
Hj CRX. How did you get the bezel open? I have the SS model, cant get my bezel off.
