:sunglasses: mod, very helpful idea.
Thanks for getting me a good price on the light :+1:
No problemā¦when mine arrives, I will re-visit this thread and perhaps will be my first foray into a little modding.
I know how much of hassle it is to lock-out each and every timeā¦or I will just use the bigger holster of my EA11 to avoid accidental turn-on.
Very nice, CRX. Love your mods. What size trit did you use? Did you have to machine the switch any, or did you just use the existing recess?
Thanks very much, it is a 6mm x 1.5mm vial covered with UV glue.
I had to dremmel a groove out of the switch to have it recessed, it was a real pain to do but turned out ok.The black stuff in the cutouts is JB Weld. I wasnāt happy with the GITD stuff.
Very cool mod CRX! :+1: :+1:
I wish I could do it on mine Olive Mi7, but Iām still a (not that skilled) newbie.
Thanks mate, maybe one or two 6mm x 0.65mm trits with some uv glue would go nicely in the existing groove, just a thought.
Thanks for the tip Stevi , but Iām affraid Iāll just screw it up if I try to do such a mod. My fingers are anything but small/steady and Iāve never been good at glueing (and dealing with) very small parts.
I really prefer this version ! The trit embedded in the switch is really smart !
Yes itās much better, thanks
Its good to see the CRX mods continuing. :+1:
I hate you.
(Donāt worry itās just jealousy :D)
Very nice mod. I love what you did with the switch.
Can you recommend a source for the Trits? My olive green Mi7 needs some bling.
Thanks,
Bob
Thanks for the recommendation. They have a huge selection.
When you say āexisting grooveā you are referring to the four existing that are parallel to the switch correct?
Thanks,
Bob
Yeah that was my original idea, I had ordered two 6mm x 1.5mm vials but they were too wide to sit in the grooves at either side so I decided to dremmel out the actual switch to make one fit.
I also thought one or two of the 6mm x 0.65mm trits could sit in the existing switch groove and be covered by a dome of UV glue but they would probably be better in the slots each side of the switch as it protrudes enough already.
Perfect. Thatās what I was thinking and what my measurements said but I just wanted to double check.
Thanks for the quick response.
Bob
No problem mate :+1:
Is the head of your titanium MI7 glued?
