a new EDC light of 2017- JAXMAN E2L
Sweet, is that the new 219C 90+ high cri LED? Would be awsome.
Ordered a Warm White yesterday. A triple for under 30, heck yeah……18350 and a 18500 tube….uhhhh yeah.
Jaxman, you’re getting better and better! :+1: :+1:
anything over about 90mm long is too big for what i consider EDC
wle
cause you cant have that and 900 lumens at the same time?
they are hitting 2 different market segments, High Brightness and High CRI
in category Products > Strong Light Flashlights they list E2L w XP-G2 900 lumens (6 watts)
under Products > High Color Rendering Lights, they list the E2 w Nichia 350 lumens (5 watts)
personally I also agree a Nichia Tripple is appealing, and I expect it will follow…
Triple of 219C D240 with 700mA have output more than 700lm . It’s pretty good.
Some introduce pictures to the E2L’s LED and lens assembling:
Very nice looking, and have already ordered one. I do wish the MPCB was not glued down with adhesive :frowning:
I have a U1 (UV365).
I wanted to change the led by a Nichia 365, was not possible to remove the old glue (epoxi type).
I had to change the pill, it is the same as the Convoy S2+
I really like it but as long as it is glued I will not buy it, sorry.
如果您推出日亚高显色LED, 加上18350短管, 那就更好。
Do not listen to him, 黑 is needed. :slight_smile:
jaxman
10x for your efforts about that, it seems to be a lovely torch indeed, will post again when i got it
Yet, i was wondering, meanwhile would you be so kind to post here a close detailed photo of those S4 1A emitters ? They could end up being from the “gold ones”….woah :sunglasses:
Lol, I bought one with 1A emitters, just to be replaced, I did think about them as being potentially one of the ‘good’ XP-G2’s. I will post a picture, Mitko!
Looks like far too much heat transfer goo.
It should barely fill the microscopic cracks in the metal surface and leave as much metal-to-metal contact as possible.
Unless the “new” means it’s some magic material that’s as good as metal at transferring the heat.
Chamfering:
Applause! Good practice.
Unno, looks like plain ol’ Fujik to me.
If it dries rubbery, should be (relatively speaking) easy to pry off.
If thermal epoxy, well, yah, you’re SOL.
Yeah, but the idea here is to help manufacturers educate the folks they hire to build the flashlights — since we can’t talk with the builders directly.
And sometimes the manufacturers miss little things and we early adopters mention them. So I’m suggesting too much thermal goop as worth checking on.
It’d help to know what’s “special” about the thermal goop they’re using, and to hear that they understand how very little of it ought to be used.
Just, you know, nitpicking.
C’mon, is it too much for a guy to ask for his Nichia and shorty tube? :wink:
I do hope it’s silicon based. I spent several hours removing a LED star epoxied down to a light once, tried heat, freezing, and enough prying that I eventually split the star into 2 separate halves, both still epoxied down.
Yeah, that’s one of those situations where you just Dremel out the damned thing.
Aw, shucks. They designed it to be uninteresting to folks like us.
What, they can’t imagine a better emitter coming along anytime, ever, that we’d like to swap in??
