Ages ago I worked with an economy recording studio for awhile. Their sound stage was a room with acoustic tile ceilings and the walls were draped with heavy carpet and old quilts hung a few inches away from the solid walls. It worked excellently to reduce sound reflections. When we did road shows we covered offensive hard surfaces likewise to ‘pink in’ the sound. I also learned that it was very important to match the mic to the vocalist or instrument but I never learned how to select them. The owner had about 20 mics to choose from. I credit a lot of my current deafness to those days of loud rock and roll
I’ve seen your vids but with my bad hearing all I can offer you is 1- cover the hard surfaces and the wall(s) opposite or near your mic position; anything is better than nothing and it needs to hang loose. 2- try different mics till you get the one which works for your voice. You need the best sound you can get to start with or the results will sound like modified junk
The studio is long gone as is my friend who ran it or I’d have better input for you. Had I not been ‘deep in my cups’ during those years I’d remember more
Actually, the “effects” may be exactly what you need (if you’re looking for a simple fix for your recordings). Effects aren’t just for making stuff sound weird. Some effects are made specifically to make stuff sound less weird. Anyway, send me a file if you’d like, and I’ll see if I can figure out the simplest, most effective fixes for you to implement, since you’re talking about doing this from now on yourself.
For anyone wondering, that line I read is from the CAD user manual. It was sitting right in front of me when I hooked up the mic for the first time. I’m not trying to sound like and advertisement!
I used Cyberlink WaveEditor2. It’s a lame program, but I can apply custom equalizer settings to a file and save it. I played with the bars for many hours, and that was the result. To re-create it, you can pull the 2K frequency down to –4 and pull the 125 frequency up to +2. Then shape the rest of the bars into a smooth wave look around them. Ending at 0 at both ends of the equalizer.
it actually sounds pretty good
i don;t hear any room reverb or artifacts
you are not popping p’s or s’s
voice range is good , not too low and muddy
i;d just say a little compression, if you have not done it already
be confident, you sound uncertain on the last few words
The original is good, but have a listen to the 2-choice clip. I think the edits in the 2-choice clip reduce the microphone feel.
The hesitation on the last few words was because I have read that line from the manual so many times I was having to resist the urge to speed-read
