That is not unusual for older (non Eneloops) NiMH cells. If the charger cannot detect the -deltaV and the voltage does not reach the V cut off, then the charger will keep cooking the cells. I have found my DRAGON to be much better at terminating older cells than my BQ-CC16 and Lii-500.
I know this but where is the energy going, i have had cells that are overcharging or have high IR get too hot to hold at this same current, but these stay cool or sometimes get warm.
I wish, but the same batteries in my BC700 do the same thing. The temperature regulation of the Dragon does not work though, i have had other batteries get too hot to hold but still charging, the 15C max regulation they claim is nonsense.
Thanks everyone for ALL your input. the more I read this the LESS I want this charger!
-No Voltage read out
-No current readout
- From what I see only displays 2 channels at a time on the LCD screen, 1 & 4 OR 2 & 3! WHY not 4, unless I am missing something. I have yet to see a photo of ALL four bays displayed w/ info.
-Of course the price!
-$69 was the cheapest I saw it on Fast Tech w/ BLF code [USA Power supply version]
-Ordering from China not something I have done too much. I much prefer the customer service in my country,no worries!
Mine does up to 4.15V, though it says 4.2V in the voltage tester, the calibration is off, and is not adjustable AFAIK. If you buy you may or may not have better luck.
Two bays is correct, there is a scroll button
That drives me nuts! My K/power L2 and Efest LUC V4 NEVER give a full charge either! they come off @ 4.15/16v. Same thing in regards to the chargers voltage meter over estimating the charge. I know 3 or 4 hundredths of a volt is no big deal,it is just that I want a full charge!Another thing is that if it is an older, it may come off at 4.14v and then settle @ 4.10/11v.
My Fenix ARE-C2 and a Trustfire 003-P4[my first charger!] are the only ones I have that give a full charge. the Trustfire takes forever [about 12 hours for a 18650 3400mAh going in at 3.60Volts! The Fenix is under 2 hours!I use the T’fire as an emergency charger or for very old batteries.I am certainly not fond of their batteries[do not have any!],but this charger is almost 5 years old. Although it takes forever, it does its job!
One thing I am not totally clear on. The mAh readout it shows while charging.That is the Capacity of the battery, Right?
The “D” Ni-MH battery they show on Xtar website is 90% full w/ 5023mAh. It obviously can NOT be charging just over 5A when 2A is the max!!!
I guess I just answered my own question!
EDIT: I just thought of something! They must be talking about the EXACT charge current because .5a/1a/2a is always displayed.
Speaking of that type of display. The Fenix ARE-C2+ has the current display, but in my mind it is useless! The charge current is ALWAYS 1Amp[bad design] so the only time you see the charge status change is when you first put the battery in and at the end of the charge before termination. Other than that it displays 1002mAh in bay 1/2 and 1004mAh in bays 3/4!! lol
the mAH reading is how much juice it has put in the battery, it counts up from zero until the battery is fully charged. Its not the capacity unless you drained the battery to zero before charging which is not a good thing for battery health to do.
Actually its very useful, by knowing how much went in you know how much of the battery you used.
IIRC this charger does have a capacity measurement ability
Thanks for posting your observations. I, for sure, will not be forking over big $ for a unit that falls short on charging.
Undercharging is a pet peeve of mine. I had a Nitecore D2 that typically stopped at 4.16 to 4.17, (even though it showed 4.20 on display), replaced it with a Xtar VC2 plus Master, and it terminates at 4.198 - 4.21.
Capacity in can be useful as bort said. If I usually put my cells in at 3/5/3.6 let’s say a NCR b and it takes 2500mah to charge. Well then I know when I put it in about how long its going to take and how much it should take in. If it takes a lot more I should look and see of the ir is increasing. Voltage is very helpful. Once you charge a certain type of cell so many times you can estimate how drained it is by just the voltage.
This charger would have to be $40 for me to consider it. I can’t see any reason to choose it over the opus. I don’t need 3 series charging. And have a dmm. And with the opus I can run a test in once slot and run a regular charge in the next can’t do that on the dragon. And I can still charge at 2 amps in 2 slots or 1 amp in 4.
But I do like my vc2 and would get this charger for sub $40 shipped. Considering I can get another opus shipped under $30 on sale
