If (note the “if”) that is the case, then, modding (e.g., replacing the emitters with some other emitter) would only encounter the glue because of having to somehow getting the MCPCB unglued from the shelf?
Maybe instead of doing that, could the emitters be reflowed “in place”? I have done that in the past with some lights (Nitecore) using a heat gun. They weren’t triples though…
I mentioned… probably in this thread, not sure… that it looks like plain ol’ Fujik, not thermal-epoxy, so it’d be the typische rubbery goop that’s often used in lieu of actual thermal paste.
Once someone gets a light and dissects it, we’ll know for sure.
Wonderfully thick chunk o’ copper from the looks in the pic, so you could probably just shave right through it with an Xacto™ blade.
That should go perfectly well, especially with a heatgun. The emitters may wait to reflow until the entire head has heated up enough (but the driver is removed anyway I suppose), but that will not have been different with the Nitecore.
If you haven't ordered yet, you may want to check with the OP to see if the following offer from post 75 still stands. If not, your reflow in head idea sounds promising. It would be hard to pry out the MCPCB from inside a head on a fixed shelf without causing some damage.
EDIT: If there is a part of the MCPCB exposed over a hole in the shelf, you can probably push the MCPCB up. It will likely bend the MCPCB, but they can sometimes be reflattened or replaced at not too much cost.
Are you going to stalk every tube 18650 light thread with your request ?
I, for one, love compact tube light 18650 but you will not make a supplier create a flashlight just for you…
Short answer…… Nope.
I taught school for almost 30 years, I had some Jr High kids that could no doubt have “broken” a superbly heat treated steel brick if given just a bit of time…… :person_facepalming:
It always utterly amazed me at how easily they could tear something up that would have lasted me a lifetime.
And they were not doing it on purpose either………… :person_facepalming:
Well whoever hit my rude button, sorry first and thank you second, you don’t know rude…!
Got the E2L today, have pictures but haven’t uploaded them yet and don’t know if I want to waste my time.
First I’ll tell you the stainless bezel is not glued,
I took it off with my hand, it has glass and gitd ring, gave it a couple taps on the desk to see if that optic would just maybe drop out but no, didn’t really expect it to really,
It legos with the regular E2 and it legos with the S2 and others same Jax threads but I was using a flat top so it didn’t fire with the S2+ tube and there’s a bit of space with the convoy tube, not ugly but maybe button top or drop it a thread,
Real nice machining of course, that’s Jaxman not sloppy.
I don’t know, what I do know is I’m not thrilled and see a rebuild for sure.
I watched that vid on youtube on this new triple and already new and expected that stainless bezel (to you builders you know what I’m saying, the angle cut on the bezel reflects into the beam, easy fix though) was going to be a problem issue, heck you can see it in the pictures the OP pics, reflects in the beam horribly,
The head looks very nice compared to the older E2 head a bit smaller head and light overall.
I’ll post pics if asked because your the gang but honestly there’s nothing to see that I can ’t say
Edit: It is priced exactly right, seemed to have forget this is only 900lm but really is just right for this light, the light grows on you once you understand what kind of light it is, might need a rebuild, but what doesn’t get rebuilt… nothing in my world, well M43 only changed lenses.
