Was this question answered? I normaly prefer a L-M-H setup and want to access the higher modes quickly bydouble or triple tapping from off.
How do you programm the double-tap mode? Can you disable it? I do not find any information in the description…
When programming the brightness it cycles through the modes, right? So you can accidently go into direct drive, I think. What happens to the LED if the battery allows very high amperages?
It’s a medium fast double tap. Yes. You can go into by accident when changing modes fast.
When programming it ramps up from minimum so you can avoid direct drive. The problem is that I think double tap and maybe the last mode are at max. I wish Dr Jones would limit the stock max modes. I was programming with a single 219B and (silly me) a high current cell. Nothing blew up but the LED would go blue after a few seconds.
I love the double tap Turbo feature, Normal people can use the light and never enter or know (Turbo) is there , it is only the Professional Flashlight experts that get annoyed when fast clicking! Or forget to get out of Turbo when shutting it off, next turn on BAM! :person_facepalming:
I use the double tap to always go to moonlight mode. I try to have ML on every light that I build and it is nice not to have to go past a mode that makes so little light you cannot tell it is on, but at night I can double tap a know that it will not blind me the next time I turn it on!
I would like to echo the hope for the H17f in other sizes as well. I would love to see it in 20mm.
It would be my favorite if it could reverse modes. But, given all that is programmable on it… I bet there is not room in the firmware for the mode reversing bits. I do find myself using the triple down style often for this feature. But having the ability to set every brightness level is awesome.
Can anyone add to the discussion from the nichia GB thread? I remember reading somewhere regarding a limit of 10A for the FET used. TA mentioned it to be more of a reisitance/heat issue and not a limit on what the FET can output.
A quad/triple will pull more than 10A and I am wondering if this driver is okay for that application?
I have not had time to test this driver in my triple 219c. I will try to get to it this week. I have been wondering the same thing. If it is an issue, it would be the get having higher internal resistance. I have read that it does.
I built an S2+ with 219c triple and H17f driver. Seems to run fine even on turbo modes. I haven’t done any readings on it but I only run turbo modes for the wow factor. So far the flashlight is running fine but does get hot quickly on turbo. I too would be interested in some scientific data of a triple 219c and H17f.
Off topic side note and I apologize for this:
Matt, I noticed in your sig you carry those S2+ xml2 and TIR optic. You should let me make you a boom-s that will fit that S2+ and a pill. I’m sold on the boom for the xml2. PM me if you want to see some beam shots.
Earlier in this thread it was stated that the FET on this driver has about 30 mOhms on-resistance. Larger FETs have around 3 mOhms on-resistance. So this higher-resistance FET will reduce the current in direct drive some. The extra resistance would be in the same ballpark as using a non-high-drain cell with 60 mOhms IR instead of the 30 mOhms of high-drain cells
At 10A the FET would be dissipating around 3W. It would most likely get very hot and this is probably the limit of what a small part can dissipate without better heat sinking.
I’ve been interested in this driver and firmware. But never pulled the trigger at mtn. One thing I hate is turbo timers. Is there anyway to config the settings to disable the thermal regulation like you can in bistro.
Same reason I don’t use a6 drivers unless they are reflashed with no timer. I can live with a 3+ min timer. It just gets aggravating to keep bumping it up every 30-60 seconds. I use my lights on turbo mostly. Searching for critters outside. I don’t have to worry about unwanted turbo use so much. Would be great to disable to thermal sensor without doing anything on the driver.
This driver doesn’t have a turbo timer. It has thermal regulation. If you are on the fence about trying one of these drivers, just do it. This is the only driver I’ll build on unless specifically asked otherwise. Hands down the best 17mm driver out there if you ask me.
Edit: forgot to mention…you can turn the thermal regulation off if you want.
